Question about Video Game Consoles & Games
My atari 2600 jr powers up fine. i put in a known working game. the game shows on the tv, however its a very jumpy picture. color is good, just real jumpy/rolling/sliding and on the fritz. how can i fix it? also there is absolutely no static or snow. its clear, it just does not hold stay steady. thanks
drknow
  • 44 Answers
SOURCE: atari 2600 fuzzy screen
Hello, Are you using a newer flat panel or and older TV? IF you are using a newer TV the picture will never look very good. IF not, did you try working with the RF adapter? Check all connections. If all else fails try to get another RF adapter to see if that helps. I remember this being a bit problematic even when these were new. Wish I had a definite answer for you! Good Luck - Dr. Know
Posted on Dec 23, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: Atari 2600 Jr. left on overnight, next day no color
Flip reset switch, then retry b/w/color selector (or switch from ch. 3 to 4).
Posted on Dec 10, 2008
SOURCE: Just hooked an atari 2600 jr. up to a lcd
Had the same problem with an atari 2600 jr I just purchased. The reset and select buttons are imprinted on a plastic film and it has probably deteriorated.. I repaired the traces in mine with aluminum tape, but It would not be dificult for someone with a soldering iron to replace them with real buttons purchased from radio shack. (It's only 3 wires)
Posted on May 21, 2009
  • 18 Answers
SOURCE: Atari 2600 Console Power Adapter
The Atari 2600 adapter has the following information on it:
Input: 120V AC 60Hz 12W
Output: 9V DC 500mA
Positive tip
Make sure you test the power supply before you use it. I have 2 original atari power supplies, and they are both putting out about 15V DC, which may be why my atari's aren't working anymore!
Anubis
Posted on Jun 17, 2009
SOURCE: Atari 2600 does not have picture when turned on.
The signal is output at 56MHz or 60MHz depending on the channel you use. Normal tv is around 350MHz to 700MHz so you need to got to the bottom range to tune. Also check that the contacts of the game catridge are not black looking, if so clean with some alchol to remove the soot build up, this will make sure the screen is outputted in proper format.
Posted on Aug 08, 2009
Atari 2600, only get black and white, no color
Well i think that the rf switch might be causing the problem snowy tv scrren no colour or fuzzy tv screen then its the rf switch thats causing this type of a problem then. If using a digital tv you need to plug it into a VCR or a DVD player for it to work then.
Dec 14, 2011 | Atari 2600 Console
I purchased an atari 2600 junior on ebay recently. It turns on fine, the cartridges have been cleaned (by myself). I have a female rca to male coax adapter to attack the rca cable to. I then attach that to...
Try switching to a different channel. The Atari 2600 supports channels 2 and 3, you want to pick the one that is not broadcasting in your area. If your TV has "auto-tuning" you may need to manually add channel 2 or 3 (whichever you pick) to see it on the TV.
Jun 17, 2011 | Atari 2600 Console
Atari 2600 Jr doesn't turn on
Sounds like the power supply\power converter has finally given up the ghost. It will likely cost you more than it's worth to fix it. You'll have to fix it yourself most likely. I would look for burned-out or popped capacitors to start off with. They are likely culprits in even computer systems when the power goes out. With something as old as an Atari 2600 it could be just about anything.
Jun 15, 2010 | Atari 2600 Console
My 2600 works fine but after 5 mins or so there is a static noise which starts through the tv speakers and the longer I play the louder it gets until I can't hear the game any more. Why?
Try a different channel on your TV. If your using 3 then go to 4 or vice versa.
If that doesn't work then try a different RF Tuner cause those are known to go bad over time. You can also try those Coaxial adapters that allow you to play your Atari on your Cable-Ready TV using the cable connection on the back of the TV.
Finally if either of those don't solve the issue, try playing different games and see if the problem happens after playing 1 games or all games. If its all games then that means there is a problem with the mainboard inside of your Atari.
Apr 29, 2010 | Atari 2600 Console
I just got a Atari 2600 as well and can't get it to produce a picture. The transducer and the chips are getting warm when I turn it on, so I know it is getting power. I have tried to clean everything with rubbing alcohol but nothing has worked so far. I have also tried about 7 different games all do nothing.
Is there some part or component that commonly goes on these systems? I have a friend who also bought a 2600 and he is having the same problem.
May 27, 2009 | Atari 2600 Console
Just hooked an atari 2600 jr. up to a lcd television, everything works fine except for the select and reset buttons.
May 02, 2009 | Atari 2600 Console
Atari 2600 does not display a picture when turned on
In this situation what I would do would be to replace the cable that runs from the Atari to the TV. Also, if you are using a variable power supply, make sure that the power supply is set on the propper settings and the polarity is in the correct setting.
Feb 25, 2009 | Atari 2600 Console
Atari 2600 jr. console + paddle controls = Don´t work !!!
get a refund for the item
then buy a new console
Sorry but thats the only way your gunna get this to work :(
pls rate.
Dec 17, 2008 | Atari 2600 Console
Atari 2600 Jr. Video Issue
You can't run a 2600 on composite. Even though the connector looks the same it isn't. You need a RF modulator to seperate the signals and you need an old school one that has a manual switch on it. Check at Radio Shack they carry things like that.
Modulators with AV jacks like I use for watching my DVD on when I only have a coax on my television won't work becuase the atari line doesn't separate the signal outside the box by audio and video. That wasn't something being done 30 years ago. In fact it wasn't being done until NES came out.
If Radio Shack doesn't carry it you can probably find one on E-Bay.
You can always find classic Atari 2600 games for your PC. I know I play the Activision Games that way from time to time.
Good luck on that.
Jun 17, 2008 | Atari 2600 Console
Apr 08, 2008 | Atari 2600 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
