Question about Garden
1975 MURRAY RIDE ON 11HP 38 INCH CUT WHAT OIL SHOULD I USE IN THE DIFF
  • 202 Answers
SOURCE: Murray 20 hp
probally trash in the carb or fuel filter partially clogged. try replacing the fuel filter if no go the carb will need disassembled and cleaned.
Posted on Jul 14, 2009
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
bargainbin2
  • 123 Answers
SOURCE: my murray 17 hp 42 inch cut hydrostat mower will
Hydrostat transaxles are very picky like the trans in your car. It must have clean fluid and be full of fluid. I am not saying to fill that transaxle to the top but make sure it is to the top of the fill line. Also it needs to be changed every few years and keep it clean to help it stay cool. If it has a filter make sure to change it when you change the fluid in the transaxle. That fluid is nothing more than 20-50W motor oil.
Posted on Sep 01, 2009
  • 29 Answers
SOURCE: I have a Murray 6.0 hp 20 inch push lawn mower. Ho...
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
Posted on Jun 04, 2010
  • 13 Answers
SOURCE: need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Posted on Jan 05, 2011
Rideon was under flood idrain engine oil do i have drain gaer and biff oil as well. and what oil do i replace gear oil with.
Yes, you do have to drain the gearbox and diff as well, because the oil in them will also have water in it. For the gearbox, use SAE 90, Gear oil. The diff will use the same oil. Don't forget to clean or replace the spark plug, and clean the Carby.
May 02, 2015 | Mtd Yard Machines 38-Inch 12.5 HP...
What size drive belt for Murray 38 inch cut model
GO TO LAWNMOWER SHOP THEY WILL LOOK IT UP AND HOPEFULLY GIVE YOU THE RIGHT BELT SOMETIMES THEY MESS UP GIVE WRONG BELT THEY WILL FIND RIGHT ONE
Sep 01, 2014 | Garden
Owners manual for 38 inch cut
you need a mower model number, not a n engine number to help you
Jul 18, 2014 | Murray Garden
Need diagram to replace murray 42 inch cut belt
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
