Question about Saws
Switch dose not work on my 7in 60088 wet saw. need to purchase new switch a.s.a.p.
    Novelist:
  • 157 Answers
Hello. Here is a link to Hitachi customer service locator. Enter your postal code/zip, chose atype of location, and click search. You'll get a location, if none are satisfactory - just choose the "contact us" option.
Hope this helps.
Posted on Mar 23, 2011
Wet plug wont start and really smokey when it dose start
perhaps you are using too much oil , and if so the exhaust might be plugged . had similar problem with a roto tiller . burnt out spark guard muffler and walla it was fixed .Old guy was using 4 times the oil required .
Aug 31, 2015 | Husqvarna Partner K 750 OilGuard Saw
Switch won't work
Take it apart and fix the switch or put a new, different switch in the circuit. May just be a broken wire. Jack
Nov 23, 2013 | Roberts 10-22500 QEP 7 Tile Wet Saw
Dose not cut in a straight line wonders
First question: What are you cutting? Are you cutting wood? If you're using fence, I need you to make adjustments on it . The nature of the band saw is to drift either left or right being parallel with the band saw fence. Is the blade tension too tight or insufficient? Check your manual for correct tension or you can just see in the tension gauge on your saw. Please this blog on how to check the correct blade tension . What is your feed and speed rate? Make sure the you're not feeding the wood too slow or too fast. Are you using new blade? Your blade is may be dull or low quality. I purchased my blades on www.sawblade.com . Their Haltbar 201 Series works great on general wood cutting.
Last question, have you taken up time to tune up your saw? See this blog for your reference.
Sep 11, 2013 | Craftsman Saws
Ryobi WS721 wet tile saw blade wont turn on start up
I just got one of these and the same thing happened, arbor spun slow and hummed. I fixed the problem by removing the motor mounting bolts I wiggled the motor and the arbor spun like a champ. When I reinstalled the bolts I checked the motor after each bolt. What I discovered was the bolts where the cause of the binding so I relieved the pressure by loosening the bolts a quarter turn each. Saw now works perfect. Design flaw!
Aug 20, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Won't start .is 70# compression enough. Spark and fuel ok. Took off carb and cleaned it. Doesn't even fire with small dose of starting fluid
70psi compression indicates it's rebuild time; the compression should be double that. You can confirm what the compression should be with good rings by putting a few drops of oil in the spark plug hole and testing compression "wet". That figure will be what a new saw would have.
May 20, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
MY SWITCH WENT OUT ON MY TILE SAW WHERE CAN i GET
You can get the part from husky website at:
http://www.huskysupport.com/products/product.aspx?ID=4
From there scroll down till you see part number
6102018
switch Knob for $5.38
Hope this is what you are looking for
Nov 30, 2009 | Wet International Husky 7" Wet Tile Saw...
I PLUG IN MY CIRULAR SAW AND IT DOSE NOT WORK
probably the plug, or the switch or the cord where it enters the tool
Nov 21, 2009 | Black & Decker Saws
The wet saw husky thd 950l wore out yhe bearing and make
I am a contractor who has used this saw for about four years. I just ordered the new motor for $79. The Husky has been a great saw. Don't waste your money buying some junk for Harbor Freight.
Oct 14, 2009 | Wet International Husky 7" Wet Tile Saw...
Dewalt ds2400 wet saw will through in line breaker not start
sounds like the breakers working to good,i would by pass the reset switch,most likely that switch is bad anyways,we always plug our saws into a outlet box that has a breaker in it ,you know those reset switches are stupid, by pass the reset switch like it wasnt even there,and if that works i would replace the whole cord with a new 1,and buy a 5 dollar junction box that has a breaker in it,i dont know if there is a seperate plug on that saw where u plug the water pump into, if there is i would check that plug first before you bypass the switch.good luck chad
May 14, 2009 | Dewalt D24000S Wet Saw With Stand
Saws Logo
60 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
