When the machine displays "unbalanced"
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
You may have to switch it off and on again to clear the display.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 23, 2011
Maytag top loading washer goes straight to agitation, won't fill with water.
you may find that the water sensor is not working as it should, unplug the machine take the back off locate the small 5mm pipe going upwards take it off and blow gently into it you should hear a click and one when you release the air, if so then the place you took it from is blocked, clean it out with a pipe cleaner or metal rod replace the pipe and rear panel and run the machine again, try to make Shure that you always fill the machine to its recommended load to prevent unbalanced loads eric
Jan 11, 2018 | Maytag Washing Machines
Tip
Windows 7 not Genuine
Ever had the Window 7 not genuine above.
You can simply solve that problem without any crack or hacking. any on without much pc knowledge can do this by following the simple steps below.
DISABLING WINDOWS UPDATE
  1. First make sure windows update is off (that is what caused the problem)
  2. Right click on the "my computer icon"
  3. choose "properties" from the context menu
  4. Look for "windows update" on the left hand side of the displayed property box and click on it
  5. from the next user interface look for the change settings and make sure windows update is turned off.
  6. NOTE: THE ABOVE STEP IS NOT REALLY NECESSARY BUT A PRECAUTIONARY MEASURE TO AVOID FUTURE ISSUES AGAIN.
NOW TO THE MAIN WORK
  1. Go the "start: menu and click on "run", if you do not find it simply hold down on the windows logo key on the key board whiles you press r on the keyboard.
NOTE: YOU CAN ALSO JUST TYPE "cmd" without the quote into the windows 7 search box. You should get only a single result since it is the only file in windows with such a name. Right click and choose "run as administrator" and follow step 3 below.
  1. From the small box type "cmd" without the quotes
  2. NOTE: YOU CAN ALSO TO GO THE C/WINDOWS/SYSTEM32/CMD right click on the cmd file and run as administrator if you find issues.
  3. type slmgr -rearm and press enter
  4. wait for the confirmation massage and restart the windows.
  5. YOU ARE DONE
on Aug 03, 2011 | Computers & Internet
What does "ue'"mean?
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Jun 29, 2011 | Samsung Washing Machines
I have washer machine wm2277hw LG., Tromm., this machine have flash light "" LE"" Error, what is the problem?
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
May 22, 2011 | LG WM-2277HW Front Load Washer
How do I get my machine to just spin a load? It became unbalanced and I adjusted it and now just want to spin the water out?
Turn power on. Without selecting a cycle, push the spin speed button to select the spin speed you desire. (if you had an unbalanced load, I'd suggest a low spin speed. You can repeat after with the next higher speed if desired) Push start.
This will give about a 12 to 14 minute pump and spin only cycle.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
Constantly going into an "unbalanced
need to replace the support drum of your unit,the coz of this one why its wort out is overload every time you use,put exact amount of kilo in dryer for long last use,now the support drum is not easy to remove only the service technician can do that coz we need to dismantle the unit to replace that part. i dont know how much the price.again dont try to repair this one coz is hard,
Jan 01, 2011 | Dishwashers
Calypso has unbalanced "L5" message
LS is a "Lid Switch Error"
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display. If opening the lid or pressing STOP/CANCEL does not clear it, unplug your washer for 5 minutes.
Here is a link to a PDF manual for it also.
Calypso Manual
Nov 21, 2010 | Kenmore Washing Machines
Noisy when trying to spin. display uL instead of time remaining. Stopped, opened lid and redistributed load. Started up again. cycle continued but still displaying uL. Not sure if load still unbalanced?...
REPLACE YOUR SUSPENSION RODS. You can get them at a discount applicance parts store online for about $60. Our washer is about 8 years old and has been getting unbalanced on every load. I replaced the suspension rods tonight and and it solved the problem.
Jan 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not go into high speed final spin after rince cycle..only spins back and forth slowly and the uE indicator comes on stopping the machine. Have tried taking out a few laundry items and re-starting and...
uE is unbalanced error. When you have bulky items, wash them with a slow spin speed. Larger loads actually balance out better, so adding items might help instead of subtracting them. After the cycle completes, if you want to you can turn the power on again and (without selecting a cycle) just push the spin speed selector button and select the next highest spin speed. The load will most likely make it through the next higher speed now that it is partially spun out. You should get a 14 minute spin and pump only when you start it now.
Nov 15, 2009 | LG WM0642H Front Load
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
