Question about Philips Audio Players & Recorders
My radio model is philips commander 67 made.I need band swith of MW.I also want FM in this old vintage radio.Can you tell me the shop where i can get it repaired.
SOURCE: sharp wf 940 portable cassette / radio player
inside radio there is relay near power supply. change it and then radio will work. or clean it.
Posted on Mar 20, 2008
emissionwiz
  • 79851 Answers
SOURCE: Hi i have a ford focus 1.6
This problem is caused by most commonly by a poor Antenna ground, and 2nd the radio chassis ground.
Posted on Nov 24, 2008
remington870
  • 48 Answers
SOURCE: need an fm antenna
If it uses a simple terminal clip (similar to a speaker connection) then extra speaker wire or lamp cord thats laying around works beautifully. But you could always visit a Radio Shack to get the proper stuff.
Posted on Apr 04, 2009
  • 226 Answers
SOURCE: FM Radio static
I think this is a component issue. I had a similar problem with my 81, so I just got a new one.
Posted on Apr 14, 2009
Testimonial: "I rigged up a standard FM car stereo and connected original antenna. No problems, definitely a component issue. Thx for the info. Very helpful"
Vintage GE Portable Radio P1905B AM/FM 1966
good luck... you will need to find an OLD repair facility or do some serious ebay searching. you can however open up the unit and see which would be positive or negative
Dec 28, 2013 | GE Overature Vintage GE Portable Radio...
I have an older (10 ) years Sansui am/fm receiver model rz-5500av. It performs well, but after a power surge, the fm radio will not play in stereo. The fm stereo indicator flashes on and off. I was told...
Part of the circuit is a stereo multiplexer decoder, that decodes the fm stereo signal, I guess that is what you mean when you talk about capacitor linked to the fm band.
I do not have the sbchematics for this circuit, if you are good at electonics just grab the tester and check the whole circuit. On a radio is not difficult to find a blown capacitor.
Test also the stereo/mono switch.
Sep 21, 2008 | Sansui Audio Players & Recorders
Unable to tune in to programmes on LW, MW and SW bands. FM working fine
If you are experiencing bad or NONE AM (MW) reception ,if your receiver has an external antenna connection point here is the solution... It should also have a ground connection as it is rare such a point does not accompany an external antenna connection.
The problem with MW reception is the vast frequency range of the MW band as" 540-1760kHz "
means nighttime fade out, and even heavy static and distortion..( less than SW )
in order to receive a station on LW and MW bands you need to have a "Loop Antenna " that normally supplied by manufacturer..if you cant locate it ,you can buy it in any electronic store..it is a very cheap accessory..additionally both LW and MW works good in daytime with powerful radio stations in your vicinity ..espacially LW..not much stations on these days..except in Europa..MW works better and more stations come after sunset ..
SW band is a little bit different.if you really want to listen SW in depth ,and if your receiver has multiple SW bands as well ,you then need special SW antenna to be attached to your receiver..otherwise it is not worth to listen it due to heavy static and distortion on the band..,unless you want it..just for testing and to see what is available in your area pls attack a plain wire (about 1 meter ) to ext antenna plug and try to search it..if you desire to learn shortwave -Listen To The World please visit the URL below.
http://www.hamuniverse.com/shortwave.html
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us
to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
Whatever I listen to, the sound comes out of my tv instead of my speakers, although when i checked the speaker volume there working
Free PDF Instruction Manual at the link below.
http://download.p4c.philips.com/files/h/hts3154_05/hts3154_05_dfu_eng.pdf
Check Page 10 Point 2.
b Source buttons
- DISC/USB: toggles between DISC or
USB mode.
RADIO: toggles between FM and AM/
MW band.
TV: switches to TV mode. The sound
from the TV will output through the
connected speaker system.
AUX/DI: switches to the external device
that is connected to the AUDIO IN-AUX
socket.
MP3 LINE-IN: switches to audio device
that is connected to the MP3 LINE-IN
socket.
Apr 17, 2011 | Philips HTS 3154 Theater System
Scratchy dials onGeneral Electric AM Fm tabletop radio
both switches need a good ceaning. go to radio shack get some contact cleaner. Make sure the radio is off take off the back spray contact cleaner into the switch while turning them back and forth. wait till dry.
Sep 14, 2009 | Audio Players & Recorders
Cd player works but not radio
No, it uses the same source.
Have you checked which band you are selecting? It has 3 FM bands, LW and MW, right?
It may not be a relay, but an untuned station.
Aug 19, 2009 | Sony CDX-GT210 CD Player
Realistic pro 2020 scanner
The Realistic PRO-2052 is an old (vintage) scanner receiver with fixed AM and FM modes on the bands it cover, as specified by the U.S. band allocation. The PRO-2020 covers only the VHF and UHF frequencies and modes AM and FM is not user selectable. Frequencies can be programmed into any of the 20 memory channels
U.S. Coverage: (varies from state to state and other countries. We don't use 30-50 Mhz here in the Philippines for 2 way mobile communications, except for cordless phones)
30-50 Mhz Lower VHF at FM narrowband only (covers mobile, emergencies, businesses, etc. and
cordless phones)
108-136 Mhz Aircraft band at AM narrowband only
138-174 Mhz Amateur and Commercial band at FM narrowband only (2 meter band)
410-512 MHz Amateur and Commercial band at FM narrowband only (70 cm band)
If you're trying to select AM or FM for a specified frequency, I'm afraid you can't do that as it is not selectable.
If you are trying to program AM Broadcast frequencies (mediumwave (MW) or FM Broadcast frequencies (FM radio stations), those were not covered by your PRO-2020's microprocessor. Even if you modify your scanner to receive those bands, you will not hear radio transmission properly since the receiver do not decode FM wideband, which is the standard mode for FM broadcast and Television band.
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Visit my website at http://mannydeguzmanartist.wetpaint.com
My talents and modeling site at http://teenmodels2007.wetpaint.com
Jul 02, 2008 | Radio Shack Pro-2052 Scanner
No am radio
You realize that the MW is the AM stations....I don't know
why they didn't just put AM on the band select...
Also I could not get MW (AM) on my set once and the
reason was that it was too close to my laptop...
It was interfering with the radio.....
May 07, 2008 | Grundig YB 300PE AM/FM/SW Radio
48 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
