Question about GE PSS26LSRSS Side by Side Refrigerator
3 problems. 1, vegetibles are freezing. 2, water dispenser on out side of door sometimes works and sometimes does not, and 3, water leaking on left side of ice maker or at least i see water freezing down the left side of the freezer starting from between the side of the freezer and ice maker. in regards to first issue, i did take the damper apart and the door seems to be work. it has resestance from the motor when i move it. thank for any ideas. rob
SOURCE: Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Posted on Apr 04, 2007
SOURCE: Ice maker
I had the same problem with the ice dispenser flap not closing properly, this cause very large build up of ice around the inside - get that sorted first.
Posted on May 30, 2007
  • 183 Answers
SOURCE: IC6 ice maker
No, completly deforst the freezer for 24hrs this will resolve the problem, i know its frost free, but still try to defrost this usaully resolves this fault Regards Advisor
Posted on Aug 21, 2007
SOURCE: Leaking icemaker
You may want to check that your water line isn't cracked.
Ours cracked and now we need to replace our floor. The water line is too close to the compressor which heats the plastic tubing and makes it brittle. Our refrigerator is 9 years old. Model #TPX24BRYFBB
Good luck
Posted on Dec 02, 2007
  • 9 Answers
SOURCE: Water Dispenser freezes
I have a 3 year old GE GSL25 refrigerator with the water/ice dispenser on the freezer door. Even when setting the freezer at 2 and turning the fridge's lower drawer to the warmer "cheese" setting, the water dispenser line would freeze every few weeks. If you have this problem, first verify that the water filter (back of the fridge) is not clogged and that water flows from the water line at the bottom left corner of the freezer door (disconnect and press water delivery dispenser-see owners manual).
I used the hair dryer recommendation to unfreeze the line by heating the flat area of the freezer door directly behind the water dispenser area (~10 min did it). The trick to keep if from freezing up again involved buying a cheap foam sleeping bag mattress (~1/3 inch or 1 cm thick) made of a polyurethane foam (pretty dense). I cut it to match the flat area of the freezer door behind the water dispenser and taped it to the door with packing tape. For the past 3 weeks (even with freezer at #4 setting), my water is flowing freely. Personally, I think this solves a product defect with insufficient insulation in the freezer door near the dispenser water line.
Posted on Jan 24, 2008
Frozen potatoes and soft butter, fridge not working
Anytime one of the cooling tubes is blocked it forces the cold air from the freezer through the open cooling tube or tubes so you will have spot freeze ups. Suggest you use a flexible wire like a guitar string to attemp to clear the blockage. If you heat the wire with a hair dryer, it will make the job faster.
As far as the unit resetting itself, it could be a preset condition. If the sensor are telling the control board one thing and you are trying to change settings, then the preset conditions could be over riding your commands. Get the cooling tubes cleared and see if things go back to normal.
The water dispenser - could be you have a leak in the water line running into the door or it could be the water depenser itself. Not enough data to tell - suggest you localize the leak. Sometimes flour will tell you where the leak starts.
Jan 08, 2012 | Refrigerators
The ice maker is not working right
replace the water valve and clean the coils undrer neath . ( make shure the fan under is working . mm
Jul 03, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Water in the vegetable tray
depending alot on your model
this is usually 1 of two things
1 moisture that has condensed in side the fridge or freezer, suggesting that you may a door seal leak
or overflow from a defrost problem
checks: 1 inspect your deasl seal and that all of them are free of obstrcuttion and actually seal the door
2. look at the back wall of your freezer is their
an odd amount of frost
Oct 11, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water is leaking out of the machine Im not quite sure where from.I guess pouring out would describe it better .It`s not coming from the door.
leaks are usually from valve /dispenser area on top left or from door boot. to check valves open top cover by removing 2 or 3 torx/ 1/4' screws at rear and slide back. check underside of dispenser for cracks, check rubber hose connecting valves to dispenser.
to open front and check around boot, remove top cover, remove screws beside dispenser opening (remove drawer) snap control console off starting at dispenser side. On older non teardrop front disconnect and remove interface cables from ccu at rear (ribbon cable in clips on right side. On new teardrop models remove teardrop by unsnapping at top then work down carefully, then unclip console starting at left, disco cables at right side of interface. remove lower kick panel with 3 screws on bottom. then remove 2 front panel screws. remove 2 door lock asm screws and spring clip around boot, then 2 front panel top screws. panel comes right off, carefull of boot. door lock stays behind.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No water from water dispenser
I have a GE GSH22JFTA side by side and my water dispenser just stopped working after about a year. The selenoid for the pump is buzzing, and when I disconenct the water line at the bottom on the freezer door, it water dispenses fine. the water is freezing IN the freezer door. I got some plastic sheathing and duct tape and opened my freezer door and sealed the freezer compartment so the food would not defrost and left door open to thaw out. in about 2 hours, voila.. my dispenser was working again. I suspect I'm not the only one with this issue.
Mar 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water despenser is apparently frozen
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Aug 14, 2008 | Amana AFD2535DES French Door Refrigerator
Water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Nov 21, 2007 | LG LRSPC2031 Side by Side Refrigerator
Jan 07, 2007 | GE GSL25JFPBS Side by Side Refrigerator
GE PSS26LSRSS Side by Side Refrigerator Logo
41 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
