The machine runs a full cycle without problem until it's supposed to drain..It won't drain any water but just seems to reuse the water that's already in there. we got it from a friend who had no problems with it. I was told it was only 5yrs old. What could the problem be?
    Habit-Forming:
  • 17 Answers
The problem is the diverter valve needs cleaning out or replacing. Normally the switching device on top of the valve snaps and you have to replace the hole thing.
Posted on Mar 23, 2011
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Front loading washer - water is not spinning out, clothes are sopping wet
Hi- Depending on the model the drain pump filter may be clogged; sometimes the drain pump impellers get damaged as well and do not pump out the water efficiently. If it seems to be coming up to full spin speed it is likely an issue with the pump. I'd run a Rinse cycle without any clothes in it and see if all the water drains out. The washer will not got up to full spin if it senses that there is too much water in the clothes (too heavy) to prevent damage to the machine. Probably best to get a Tech to come out an look at it. Good luck.
Sep 24, 2010 | GE Washing Machines
Sometimes when I turn the washer on; it continues to run the water without filling the bowl. Seems like the washer thinks its in rinse mode.
Check your drain the drain hose must be higher that the tub or it will run down the drain.
It must be going down the drain or you would have water all over the floor If the water is coming in it has to go somwhere. In rinse cycle it should stay in the tub until the timer kicks it into drain and spin.
Sep 14, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer won't go into rinse cycle
same problem. anyone has a solution? checked the lid switch already, it seems to be intact.
Jun 02, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
take hose and siphion the water out of the unit.run into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
thanks,
joyce
Feb 07, 2009 | Fisher Paykel EcoSmart GWL15
GE washing machine does not run, gives humming noise
A washing machine is a simple product.
When trouble shooting anything you have to know what is supposed to do and what is it not doing.
At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
When you start a cycle and no water enters the drum you have one of three problems:
1. The water supply is shut off.
2. The solenoid valve that supplies the water is not opening.
3. No power to the washing machine.
Since you are hearing a hum, the machine seems to be trying to activate that valve,
The humming noise comes from the electromagnetic field that activates the valve,
Dec 04, 2008 | Washing Machines
Dishwasher confused
i suspect this is nothing to do with switching off during the cycle.
take the bottom plate off and check if there is water leaked into the bottom pan. alternatively, if you can, tilt the machine back to 45deg and see if water runs out.
most machines have a float switch in the base so that if water leaks, all that will happen is that the drain pump runs and i think this is what you are hearing
Aug 07, 2008 | Dishwashers
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
