Question about Microwave Ovens
I have a gaggia philips kubika coffe machine .allof a sadden it wouldn t switch on .then i opened it and try to fix it by unplagging the cables.now i don t know wher the cables should be attached to
    President:
  • 1,654 Answers
Would a wiring diagram help. Try here for a diagram. http://209.85.229.132/search?q=cache:sNZF8wdWTCgJ:www.partsguru.com/GaggiaEspresso.html+gaggia+evolution+wiring+diagram&cd=2&hl=en&ct=clnk
Let me now how this helps.
If this does not help, give me some more specifics, how many wires are we talking about, switches usually only have 2 unless they are tied to something else.
Posted on Mar 23, 2011
Display show SE from samsung microwave range hood
The keypad has a short in the membrane, which means the keypad control board will probably need to be replaced.
May 05, 2012 | Samsung SMH8165STE Microwave Oven
While i was trying to prepare some coffe in the microwave after 2 minutes i opened the micro and the coffe was all over and now it's not functioning well? Can it be repared ?
Yeah a kind of. If the wave cover plate is only went bad(A rectangular plate inside the food chamber).
If you have little idea how to use voltmeter then only you can try to fix it.Otherwise,without any experience it is very risky.
First check the magnetron which produce microvave.(check two terminal resistance in isolated sysem).MAKE SURE YOU DISCHARGE CAPACITOR FIRST .MICRVAVE CONTAINS 5000V IN IT.
If magnetron is good then just clean the wave guide and replace the rectangular plate(wave cover).
it should work okay then
Thanks
Please rate my work
Sep 10, 2011 | Microwave Ovens
My new gaggia platinum vision will not prime. it says "prime water circuit" and makes several loud clicking sounds and then says "restart to solve the problem", but this doesnt solve...
We had the same problem on our machine, and it was fixed by backing the strength setting (the physical dial on the front of the machine) off from the "maximum" setting a small amount. Somehow this was creating too much back pressure, and the useless "will not prime" message appeared.
Dec 29, 2010 | Microwave Ovens
My krups xp7200 is leaking water from the bottom. How can I open it to check the problem? thanks
You need to unscrew 4 screws in the front, three on the top (underneath the lid where you put the cleaning tablet), one inside the coffe container at the top, and pull gently, but firmly the little black nob inside the coffe container, that you use to adjust the coffee grinding, straight up. Then you can remove the coffee container on the top, and unscrew one screw underneath this container. Also, remove the two screws from the holes beneath the water container. NOW, you should be able to pull the front electronics off, and pull the main cover backwards, away from the front panel. You may have to bend it a little to get it completely off, but it is not a problem. Good luck! :)
Jun 15, 2010 | Microwave Ovens
Display not lit up
Seems like the display panel went bad. You can check for sure by unplagging the unit for 45 seconds and plugging it back in. If still no display order a new display panel.
Please rate if you are satisfied
Feb 12, 2009 | Microwave Ovens
I would like to buy a breville cappuccino maker but hear the dial at side gets stuck and breaks easily,even when cleaned well after use. Has this been rectified. Doreen
Hi, apparently Brita, that owns Breville, did not fix the problem yet.
I can see that complains keep coming.
The problem is apparently on CM8 and CM9, the more expensive Cappuccino Maker BES200XL
does not have the problem.
One suggestion, Breville are nice budget coffe maker, if you want to spend some mor money on a better product buy a Gaggia or something similar. Italian coffee makers are usually the best for espresso/capuccino. If you want a Breville buy the ESP8XL Espresso Machine.
Here is another good brand.
Sep 13, 2008 | Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
