Question about Sony KDF-E50A10 50 in. LCD HDTV
Light red translucent stripe at top of screen
I have a light red translucent stripe at the top of my screen, any suggestions?? I noticed it about 3 weeks ago.
  • 876 Answers
On your Remote
>menu
>parental controls,favs & setup
>system setup
>display
>centering
You can use this screen to move your picture up a bit and get rid of the line. If it doesnt work the first time, move it a little more. Good Luck!
Posted on Aug 03, 2008
When I turn the tv on the picture is perfect. After a while I see 2 translucent stripes on the right side of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 02, 2016 | Televison & Video
It was wired for a 4 wire flat trailer plug. the plug was ripped off and now there are wires coming from both tail lights and the drive lights on rear passenger and trailer dont work. Green, Black, brown/w...
You need to install a 3-2 wire converter. I suggest a CURT 56175 then
1.Using a test lamp, identify the corresponding wires in the harness for the left turn, right turn, tail lights and brake lights. 3. Temporarily remove the vehicle's negative battery cable from the battery. 4. Using wire taps, attach the input wires of the tail light converter to the corresponding vehicle harness wires identified in step 2 as indicated.
Converter Brown Wire: Tail Light Circuit Converter Yellow Wire: Left Turn Circuit Converter Red Wire: Brake Light Circuit Converter Green Wire: Right Turn Circuit
5. Locate a suitable mounting location for the ground eyelet on the vehicle near the converter on vehicle's frame or cross member.
And your ready to tow!
Mar 08, 2011 | 1999 Plymouth Grand Voyager
Red and green stripes (1" wide) running down the screen. Started with one red, now a green and another red. The stripes come and go at times, but most of the time they are present.
I hate to be the bearer of bad news but this is actually one of those known and predicted issues with LCD televisions. What these are called are "dead" lines of resolution aka dead pixels aka frozen pixels.
This is one of the flaws of LCD televisions, there is a completely random, unpredictable fail rate of LCD pixels in all panels, the likeliness of failed pixels varies depending on the quality of the panels used in the TV.
There really isn't a resolution to make them go away, if they are simply frozen, usually a light (VERY LIGHT) tapping of the screen at the top and bottom points of the line will refresh the pixels. If they are coming and going more often, it means that the panel is weak or malfunctioning in those areas and you need a new panel in the TV. Unfortunately it's quite an expensive repair, running at least $400 USD, if you are within warranty period (usually only 3 months for dead lines of resolution.. but it varies up to 12 months depending on the manufacturer) I would suggest calling Vizio and inquiring about a replacement TV. They generally won't allow a repair as it costs them less to simply give you a new unit all together.
My apologies for your bad luck!
Dec 09, 2009 | Vizio 42 in. LCD TV
I have a red stripe across the top off my tv
This issue is because of a defect in the light engine. The only way to solve is to replace the whole light engine. They usually run anywhere from $500-$2500 depending on the model. Sony extended the warranties for the light engine on certain models that have this problem because of the defect, contact Sony to see if a certain TV had the warranty extended.
Oct 05, 2009 | Sony Televison & Video
I need wiring to install a new radio in my 2001 f-150 acc-battery-ground what are the colors ?
Abbreviations used :
CJB ( aka Central Junction Box, cab fuse panel )
BJB ( aka Battery Junction Box, Engine Compartment fuse panel )
In the factory connector :
Hot at all times from CJB Fuse #1 is pin #9, light green w/ violet stripe wire
Hot in start from CJB Fuse #20 is pin 3, Red w/ black stripe wire
Hot in Accessory or run from CJB Fuse #8 is pin 10, Black w/ Pink stripe wire.
Grounds in the connector :
pin 2, black
pin 11 black w/ light green stripe
pin 16 black w/ light green stripe.
pin #1 light blue w/ red stripe is the instrument illumination, after the cluster dimmer switch.
I would stay away from using the black w/ light green stripe, I seem to recall those are the shields for the speaker pairs.
Bit late on the reply, just caught this one. If you don't have it don't, good luck
Sep 30, 2009 | 2001 Ford F150 Styleside SuperCrew
Need to know what color wires run my mass air flow sensor in my 93 maxda mx3 1.8l should be 2 wires what color and where to find then
You can pick up a Haynes manual. They have all necessary diagrams in them, including electrical schematics.
Regards,
matt
Sep 15, 2009 | 1993 Mazda MX-3
Large yellow blot on the left side of the screen.
that sounds like a very expensive repair I'm afraid
, it is the light engine that is bad
Larry D.
Aug 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Where are the cam sensor and crank sensors located on my car?
Crank Sensor: Passenger side of transmission just to right and above the differential cover. Has 3 wires:
Light Blue/Dark Blue stripe - Signal
Dark Red - 8v supply
Black/Light Blue stripe - Ground
If the car runs or cranks, you can test this sensor by first checking for power on RED wire with key ON. Should be 8-9.5 volts DC. Furthermore, connect a dwell meter to the signal wire by probing the back of the connector. Dwell reading should be 49-51%. If not, its likely bad.
If you remove the sensor, you MUST replace the paper spacer on the end of the sensor or you risk damaging the sensor or even the torque converter drive plate otherwise. Also make sure O-ring is in good shape and positioned properly.
Cam Sensor:
Facing Engine, it is on the driver side timing case housing, on top of the round part, just to the right of the fuel rail pipe where there is a capped fuel valve.
Has 3 wires:
Tan/Yellow stripe - Signal
Testing is same as for Crank Sensor.
May 14, 2009 | 1994 Dodge Intrepid
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Sony KDF-E50A10 50 in. LCD HDTV Logo
134 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
