Question about Olympus FE-320 Digital Camera
Camera stays on "one moment"
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Jul 04, 2011
How can transfer images from Camera to my pc.?
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 05, 2012 | Casio QV-5700 Digital Camera
Camera says "communication error" when trying to transfer images to computer. Why?
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Jan 10, 2012 | Canon G12 Digital Camera
I have an Olympus FE-330 camera. When I try to transfer using the Olympus Master 2 (recently installed) it says 'software unable to locate an Olympus Digital Camera connected to a USB port' I...
Check the LCD screen of the camera. You should get a message when you first plug it in to select the usb type. highlight PC and press ok. The screen should display one moment please then go off. Then the camera should be recognized by the computer.
Jun 15, 2011 | Olympus FE-330 Digital Camera
Every time i plug in my sony camera to the usb port to upload my pictures, my camera will say " usb mode. connecting to mass storage" then that will go away after a few seconds and then it...
The "USB mode" and "Connecting to Mass Storage" message will get displayed when the Camera is connected to the Computer and is recognized by the Computer as a Mass Storage device. This is not an error message and is a normal operation.
You can change the Mass Storage settings in the Camera (depends on the model) The USB Select or USB Connect option in the Camera can be changed to PTP, Mass Storage or PictBridge mode. Set the option in the Camera to PTP and connect it to the Computer and check if the Computer is recognizing the connection. Once the computer is recognized, it appear as a removable Drive.
You can transfer the images from the Camera to the Computer from the Removable Drive by copying and pasting.
Thanks for contacting FixYa.
Apr 07, 2011 | Sony Cameras
I have a Canon PowerShot G9 camera. When i plug it into usb cord to dowload pictures, i get the error message "Communication Error" across the viewing screen of the camera.
The problem I believe is the sequence or flow of the connection.
With the camera turned off. Connect the USB cable to a computer USB port and the other end to the camera digital port turn the camera on by using the "Playback" button here is a diagram
Place diagram here
You know there is an easier and better way of transferring picture files and that's by using a memory card reader. A memory card reader plugs into the USB port of a computer and the camera memory card is inserted into the reader slot. The computer then looks at this as an external Hard Drive. Both methods will need you to format the memory card after the images have been downloaded to the computer. Formatting the memory card in the camera in which it is to be used will clean the card and making it compatible with the camera both the camera and memory card can then communicate without errors.
Jan 16, 2011 | Canon PowerShot G9 Digital Camera
Can't upload
try another usb port first, then check the device manager in the computer to if the device is listed a usb mass storage device...the other solution would be to wiggle the connections on both the camera and computer to see if the one moment goes off
Jul 16, 2008 | Olympus FE-210 Digital Camera
Transferring photos to PC
try using a memory card reader that supports a xd card-very generic plug and play no software to load and computer should recogtnize card-if not open my computer and you will find new drive letters for card reader in there
Jun 03, 2008 | Olympus Stylus 720 SW Digital Camera
Can't transfer pictures to my computer
I work as a Olympus DTS Agent. It sounds like your cable is bad or your Port on your camera is bad. One tip that I can recommend other then calling us at tech Support 1-888-553-4448 is be sure you are always plugging camera in through a usb port on the back of the computer.
Mar 25, 2008 | Olympus SP-350 Digital Camera
Transferring pictures
A couple of things you can try:
1. Insert the Camera's USB cord to another USB port of your PC;
2. While disconnected from the PC, verify that the pictures are still inside the camera's memory;
3. Reset the camera (power on/off);
4. Check the camera's batteries;
5. Reboot your PC with the camera attached via the USB;
6. Remove the memory card from the camera and try uploading using a card reader;
7. Uninstall all instances of your USB in your PC's Device Manager, reboot and allow the PC to auto-detect  and auto-install necessary drivers; and
8. Verify that the software/drivers for your camera are installed correctly with no yellow or red markings.
Hope this be of some help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 02, 2007 | Cameras
Olympus FE-320 Digital Camera Logo
74 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
