Question about Car Audio & Video
I need to know if my rockwood 1000W 4ch amp is 2 ohm switchable. the model number is AMP 4004
  • 8 Answers
SOURCE: whats the RMS on my 1000watt 4ch amp???
hi
Ive done some research and i haven't found any conclusive ending however the best i can do is tell you the round about RMS which is approx 200 to 150 unbridged.
Posted on Dec 18, 2007
mjap
  • 107 Answers
SOURCE: problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
Posted on Jan 26, 2008
sepsi
  • 7 Answers
SOURCE: solobaric subs l7 15-inch
when you drop the Ohms and put them together, they go even lower. 2ohm + 2ohm = 1ohm which ur amp is not capable of. try this, with one subwoofer on one voice coil connect the positive (+) and negative(-) together(the ones without the dots) and the ones with the dots run to the speaker terminal like normal. do this for both speakers
<a href="http://s14.photobucket.com/albums/a312/kimsam/?action=view&current=2_4ohmDVC_1ohm.jpg" target="_blank"><img src="http://i14.photobucket.com/albums/a312/kimsam/2_4ohmDVC_1ohm.jpg" border="0" alt="Photobucket"></a>
this is what you did...
<a href="http://s14.photobucket.com/albums/a312/kimsam/?action=view&current=1_4ohmDVC_8ohm.jpg" target="_blank"><img src="http://i14.photobucket.com/albums/a312/kimsam/1_4ohmDVC_8ohm.jpg" border="0" alt="Photobucket"></a>
this is what you want...
Posted on Feb 12, 2008
zzedly
  • 300 Answers
SOURCE: dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Posted on Mar 17, 2008
  • 173 Answers
SOURCE: L7 wiring options
yes it should work fine i would bridge them up to 4 ohms each speaker then bridge them back bye conectin them on the amp by puting the red with the red and puting the black with the black if the amp only has 1 chanel then put both speakers red on the same positive on the amp and same with the negative now to bring the ohms up to 4 ohms conect the solid red to the black with dot with a short wire ok then the ones that are not run together will go to the amp giving offf 4 ohms and with the 2 speakers bridged together thay will reduce to 2 ohms witch means that eatch speaker will get about 600 wats of rms from the amp
Posted on Sep 14, 2008
How do I install a Rockwood AMP-326 amplifier? I'd like to bridge it.
Rockwood was a very low level brand. Alot of their amps were not brigeable. If bridge able the bridge terminals should be marked (usually the positive of 1 channel and the negative of the other channel). Under no circumstances bridge to less than a 4 ohm load.
Jul 17, 2016 | Rockwood Car Audio & Video
How can I bridge a Rockwood Model No. AMP326 4ch amp?
simply use the two outside speaker connectors in order to bridge them
I have the Alpine MRP-M1000 amp. I want to use 2 subs with this amp. Which Alpine subs would work best with this amp?
this amp is rated at 600w at 4 ohms and 1000w at 2 ohm so as long as you calculate your speakers to match the ohm specs of the amp you can hook up
parallel = pos to pos and neg to neg of the 2 speakres
2 - 8 ohm speakers in parallel = 4 omhs
2 - 4 ohm speakers in parallel = 2 ohms
series = pos to neg of the 2 speakers
2 - 1 ohm speakers in series = 2 ohms
2 - 2 ohm speakers in series = 4 ohms
Feb 22, 2011 | Alpine MRP-M1000 Car Audio Amplifier
2 NTX-6812's. need box and amp.
if your subs are dvc 1000w max and 500rms wiring up to a 1 ohm load you would need a 1000w max 1 ohm stable amp. to put this in a pickup truck, i would not put them in a box, i would get 2 12inch tubes to put them in. cause a wedge truck box would make your system sound like garbage and will be distorted, your sql will be poor, basically you would need the right amount of air space for the subs.
Feb 10, 2010 | DHD NTX-6812 Car Subwoofer
How to fix rockwood 10 in. 800w sub?
i would double check your connections also any fuses on the amp i have blown a few fuses on my amp haven't checked into the main reason for that to happen but its common if you don't have a big enough amp... assuming that the amp is getting overloaded. I would say you need a bigger amp like 1600watt or 1800watt
Jul 30, 2009 | Car Audio & Video
Sony amp model 1652z
1000W max power
<b>
165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
</b>
OTL (Output Transformerless) circuit
Pulse power supply
Line & High Level Inputs
.3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
80 Hz, -18dB/octave Low Pass Filter Switch
Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Speaker type
I posted a comment on your other post not nodicing this one. But commenting on the choice of amps, It would all depend on what the model number is on the pioneer amp. Also it would depend on what kind of sound you want. Could you get me the model number of that and double check your model numbers for the kenwood sub and amp. The amp that I show when I googled it was rated at 250 watt at 2 ohms no where near 1000. so if I have the wrong amp let me know, I would like to help. Thanks
-Andrew Hawkins
Jun 01, 2008 | Car Audio & Video
Install diagram?
i dont know where to find the instructions, but it shouldn't be all that difficult. I used to have one of these legacy amps .....what hookups do you have on it?
Mar 15, 2008 | Legacy 4CH 1000W RED AMP Car Audio...
Whats the RMS on my 1000watt 4ch amp???
hi
Dec 17, 2007 | Rockwood XR-3973 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
