How do i get the color back right because the its a blue screen
  • 36 Answers
What's the model number?
Posted on Mar 23, 2011
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
My screen looks like its 3D.
Your tv has a problem with the convergence, adjust it using the original remote go to the setting's menu then go to the convergence section. Adjust the convergence color red and blue the green color is your guide you cannot move this green color, then you should move the red and the blue in all direction left to right, up and down. If you cannot move the red and the blue far enough the convergence IC is defective it must be replace in order to align this convergence. Feel free to send feed back good day and best regards.
Aug 14, 2011 | RCA HD56W66 56" HDTV
The colors on the screen are not right, even when ...
If the color controller (color circuit) is failing, the true colors, detail and density will be erratic. A professional technician can trace the circuit and diagnose the problem in minutes.
Feb 01, 2018 | Palm Tungsten E2 Handheld
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Televison & Video
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Sony kp-65wv700
I followed GuestUser/ Slinteriors advice and I fixed it. Open the front of the TV and there are 6 little nobs in the front. The botton 3 are what you need to adjust. from left to right the color controls are BLUE, RED GREEN. For the blue lines, slightly (I really mean very slightly) turn the botton left nob clockwise (right).
Mar 21, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Blue screen
It sounds like the Blue drive transistor is shorted out leaving the blue color gun on full blast which is drowning out the other colors. If this is the case the transistor needs to be replaced. A qualified technitian could easily replace this part.
Jan 19, 2008 | RCA F32650 32" TV
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
