Question about Onkyo TX-SR703 Receiver
Sound clips out sometimes but comes right back on
    Master:
  • 525 Answers
Try wiggling the audio jacks. If it cuts out then you have a short.
Posted on Mar 23, 2011
My bass makes no sound.
check the jack wiring, or the battery clip integrity- sometimes the clip wires break but they look fine.
Dec 16, 2012 | Schecter Omen EXtreme-4 BCH
When viewing TV with DTV, the sound will occasionally mute right after the clipping in a program. Just like the function that protects the speakers from loud sounds. (This function is OFF) The sound comes...
Just try connecting the input to another TV and check whether the same problem comes. If it does, the problem is with the input. If not, the signal strength is not good enough to the microcontroller IC to switch off the mute. Normally when the signal is missing or weak, audio mute gets operated.
Jul 12, 2012 | LG 42le5300
My jeep makes a sound from the rear for example today backed out of a parking spot and a loud clicking kinda like if u put a baseball card in the spoke of a bike only louder
Check the back brakes . I believe you have drum brakes in the back.The brake hardware. ie..Springs, clips.. come apart sometimes. And this will cause the clicking noise you hear
Nov 26, 2010 | 1998 Jeep Grand Cherokee
How do I replace the liftgate supports on a 2004 Tahoe?
Just support the lift gate with something so it does not fall down on you and remove the metal clips on the end of the support strut.Should have one on each end.They should come right off.The clips are spring tension.Just use a small flat blade screw driver.Sometimes you don`t have to remove them just pry them back enough to remove the strut.Then install the new ones.Hope this helps.Good luck.
Jan 19, 2010 | 2004 Chevrolet Tahoe
How do you unlatch the battery of a timex ironman watch. I have the back open now
You will need to look for any screws holding down a plate over the battery. Sometimes these only need to be loosened and sometimes they have to be removed. Sometimes the plate can be lifter slightly and the battery slide out from underneath. I hope this helps you. Best luck
Nov 19, 2009 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
When putting the phone in the clip sometimes it will redial the last number called. I don't see any buttons on the outside that would redial. I know the right button on the right top brings back the last...
The right button on the right top that brings back the last dialled number may be the culprit. Check to see if a long press on this button redials the last number. If so, then the clip is pressing it too long. Can you avoid using the clip or modify the clip so as not to press this button.
Nov 09, 2009 | Motorola Mobility i560 Cellular Phone
Right loudspeaker problem
Doesnt sound like the selector as it "sometimes" works. Redo the speaker connections on the back of the amp and speakers first. If it persists, swop the speakers and cables, if the problem swops, then it could be inside the speaker or the cable, if still the same then amp has dry joints/loose connections probably
Jun 24, 2009 | NAD C372 Amplifier
Brand New SAMSA CLIP Mp3 Player Wont Turn On Sometimes.
This player goes to sleep quickly. Press the center button to wake it back up.
-Tha Mp3 Doctor
Dec 12, 2008 | SanDisk Sansa Clip MP3 Player
Pls tell me how to open monitor for repair
Protocol Internet Caf'e
AL SALAMAH ST. JEDDAH
I also opened the cover of monitor but its really hard because the two clips hold it tight from the top of monitor. First I open the 2 screws at the back. Then you have to hold the cover very strong and its strongly to left and right like you are ripping it till and the cover gets free from the clips at left and right parts.Than when you look at the top of monitor, you will see little holes at the left and right sides of monitor. you will have to free them with a screwdriver. ( its mostly possible that there will remains some track:) i have 40 samsung monitor here in my cafe so plz guide me to open the cover of monitor. call me my no. 0564993626
May 14, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Onkyo TX-SR703 Receiver Logo
94 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
