Question about Bionaire Kitchen Appliances - Others
I have a problem with a IMPERIAl fryer, Model IFS 40 , The Pilot doesnot stay on no matter what i try.I keep it pressed for about a minute and when i release it goes off.
  • 3 more comments
  • PanchoRocha Mar 23, 2011
    I went to a parts store and they checked the thermopile and it was working , what do you think the problem might be , do i need still replace the thermopile or what else the problem might be? THANKS
    I checked the thermopile at the parts store and it was working fine, so i dont know what the problem might be , do you think i still need to change the thermopile? THANKS FOR YOUR HELP.
  • PanchoRocha Mar 24, 2011
    I did install a brad new t- pile and still get the same problem, the pilot does not stay lit.
    should i check the hi limit switch?
    IMPERIAL IFS 40. I have replaced the t-pile and still the pilot does not stay on , only if i keep it pressed.I ll be glad to get helped.THANKS
    President:
  • 1,654 Answers
Hi!!
What tells the gas valve to open is the thermocouple, the small copper tube connected to the valve on one end and on top of the pilot's flame the other end. When the pilot detects flame, it sends a small electrical signal to the valve to keep it open. If thermocouple is faulty, it won't send the right signal. This is the most likely cause of your problem. These run about $10 depending on the Fryer model and is very easy to replace. Installation instructions come with the new unit. Alot of thermocouples are interchangable and can be bought at hardware stores and gas/propane supply stores. If the thermocouple doesn't do the trick then the only thing left is your gas valve, but I bet it is the thermocouple, sometimes you can revive them if they are charred. Use some emory cloth and polish the old one up and it may work.
Good Luck!! A HELPFUL, 4 THUMBS UP rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Posted on Mar 24, 2011
  • Dcramer531
    Dcramer531 Mar 24, 2011
    I wish I could see what other have told you before I post a repeat of the same posts. If the thermocouple is good, then it is the gas valve. There isn't anything else as long as you have the correct pressure from the tank to the valve, I assume you have a regulator in the line, but these don't go bad that often. But they are a cheap replacement if you want to try before you replace the valve. If you gas is cold you may have low pressure from the tank.
  • 2,382 Answers
Hi, sometimes it may require you to hold down on the pilot knob on the gas valve for a couple of minutes after you light the pilot. Thermopile get weaker with age. If this does not do the trick then replace the thermopile.......
Posted on Mar 23, 2011
  • 1 more comment
  • Tunde Autos
    Tunde Autos Mar 23, 2011
    I still suggest you change the thermopile because the one you are presently using may still be working but weak....
  • Tunde Autos
    Tunde Autos Mar 24, 2011
    Hi, then there must be something tripping it off. It's either a switch problem or an electrical problem. I will suggest you check the electrical connection, the element inside the fryer and the switch one after the other to know where the problem is emanating from because ordinarily it is normally a thermopile problem....
  • Tunde Autos
    Check it...
Pilot goes out after fryer reaches operating temp. Replaced milli-volt generator already.
sometimes the hole in the pilot tube gets dirty and needs cleaned in the old days the gas man had a tiny drill bit he reamed it with .
Mar 05, 2015 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Pilot light won't stay lit after releasing when lighting gas fryer
This symptom indicates something wrong with the millivolt system. Start by checking the wires from the thermopile to the gas valve, insuring they are all tight and in place. Check the hi limit thermostat, if you have an ohm meter it should read .1 or .2 across it. With you meter set to dc millivolts, and flame present on the pilot, read across the thermocouple wires (red and white) to see the millivolts generated, with the thermostat off and the gas valve in pilot position you should get approx 600 millivolt plus minus 50. The pilot will have to be on for a minute or so to get maximum millivolts. If the millivolts are correct, hi-limit closed, and all wiring is connected, you likely have a faulty gas valve. If the hi limit reads more than .1 or .2 replace the limit, if you are not getting the millivolts from the thermopile, replace it.
Apr 05, 2013 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
Brunners will not light on my imperial IFS-40
WTF your pilot light might be out RUN LIKE HELL- air the place out then go back and re-light it.
Aug 25, 2009 | Imperial IFS40 Deep Fryer
Ifs 40 deep fryer
I have a used fryer, imperial, looks like the ifs 40 but can not find the model number on it. Do you have any idea how I can find the model number?
May 13, 2009 | Imperial IFS40 Deep Fryer
Fryer IFS 40. Burner not getting on.
If the pilot light stays lit then there is no problem with the thermocouple. What you have is a problem with the thermostat or the gas valve operator. try jumping the thermostat wires and see if the gas comes on. If so simply replace the thermostat.
Dec 14, 2008 | Imperial IFS40 Deep Fryer
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Aug 22, 2008 | Imperial Kitchen Appliances - Others
Kitchen Appliances - Others Logo
95 people viewed this question
Top Bionaire Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Bionaire Kitchen Appliances - Other Expert? Answer questions, earn points and help others
