Question about LG LHD45EL Dehumidifier
I have just had my second dehumidifier stop working. Both have been used exclusively in my basement from spring through fall. The first one (kenmore) lasted 5 years, and the second one (LG) lasted 2 years. Both appear to have failed due to refrigerant leaks from corroded coils. The compressor and fan both run fine, but no moisture is removed from the air, and the bucket never gets any water. I removed the front cover on each unit and there are 2 sets of coils in each one. In both units, the sides of the front coil are corroded around where the copper elbows go in the coil. Both sides of the front coil are corroded from top to bottom, but there is no corrosion on the back coil in either unit. I'm guessing that the frame of the coil is aluminum and this is galvanic corrosion. Is this common in household dehumidifiers? If so, what can I do to prevent this in my next dehumidifier?
    Brigadier General:
  • 4,736 Answers
Brad, you have really hit on something. In fact, it's more common than the manufacturers want the consumers to know. Actually, the corrosion starts after the unit is not used for several months and then put back into service. Is there something that can be done, on the consumers part to help prevent this? Perhaps, but, it would require routine maintenance, which most consumers don't even think about, until they ave a problem. Like cleaning the air intake filter regularly, checking the drain hole or tube for clogs and when not in use, storing the unit in a dry environment. As far as preventing the corrosion is concerned ... Doing what you did, to expose the front coils and in addition, wiping the down the coils and spraying a light coat of WD40 on them, may slow the corrosion process.
The bottom line is this. Until the manufacturers switch from aluminum coils to copper coils, the problem will always be there. But, the downside to the consumer will be, copper is more expensive than aluminum and therefor, the cost of the dehumidifier will be higher.
Again, good job, Brad! Your theory was well thought out.
Posted on Mar 23, 2011
What should I set my dehumidifier at for my basement
50%
Please rate 4 stars if this is helpful. Thanks and good luck!
Apr 22, 2014 | Kenmore 54701 Dehumidifier
My dehumidifier no longer works. It started with running almost contantly without much water output. Now it just runs without any output. I only run it spring summer and fall. It is located in the...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 31, 2011 | Haier DM30EAL Dehumidifier
Our 50 pint 54501 Kenmore dehumidifier runs but there is no water coming out. We have mold collecting on some items in basement
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 11, 2010 | Kenmore 54501 Dehumidifier
Whirlpool dehumidifier in basement has stopped taking water into
how warm is the basement,if the temp of the basement is lower than say 70 degrees,the unit will not function,true dirty coils can have this effect also and a refrigerant leak on these will cause the same result,if the temp is low,use a fan to move the air and this will help with your humidity problem too
Apr 02, 2010 | Whirlpool AD35USS Dehumidifier
Kenmore dehumidifier M/N 580.53650200 only runs for about 1 minute, then stops. Dehumidifying level is set to minimum (40) and it's damp in the basement so I know the air is not too dry. The fan works, the...
Well to knowledge the problem 40 percent is dry. means your basement is great. humidity should be 30/50 percent 50 grows mold. also if it runs for a min the auot shut off is activating. check this first.
Manifestr
Oct 06, 2009 | Kenmore 5365 Dehumidifier
Kenmore 54501 turns on but nothing happens in my damp basement
A dehumidifier heats and cools the air to remove moisture. Most are like a small air cond. The Condenser coil is right in front of the evap.coil. So the compressor may not be coming on. Does it sound the same as before? It may be low on freon. You will have to get in there and listen and feel the lines at or near the compressor, Learn how to get down in there to the compressor. Run it for 10 Mins. unplug it, open it up, and feel the lines. Some lines should be or can be HOT to the touch. Some should be cool. The smaller the line the hotter it should be, and the compressor should be warm (to hot) to the touch. repost for more info.
Jul 08, 2009 | Kenmore 54501 Dehumidifier
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Buzzer going off
compressor or compressor overload problem
Apr 09, 2008 | Kenmore 54701 Dehumidifier
DEHUMIDIFIER | ADR556RH
The Efficiency Factor (EF) is a guide to a dehumidifier's operating cost. The EF is the amount of water, in litres, a dehumidifier removes at 27°C (80.6°F) and 60 per cent relative humidity for each kilowatt hour (kWh) of electricity. If electricity costs 8 cents a kilowatt hour, which it does in many parts of Canada, a unit with an EF of 1.2 will remove 15 L (32 U.S. pints or 3.3 imperial gal.) foreach dollar in electricity costs. An advanced unit with an EF of 2.4 will remove 30 L (63 U.S. pints, 6 1/2 imperial gal.) of water for each electrical dollar spent. Because condensation gives off heat a dehumidifier acts as a heat source. This can be useful in spring or fall, when basements tend to be cool. In mid-summer, the heat added by a dehumidifier is counterproductive.
Sep 07, 2007 | Danby DDR583R Dehumidifier
LG LHD45EL Dehumidifier Logo
613 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
