D2d hi! my prob is i dont have d orig recovery of my aspire 4720z and when i open it,it will not continue to windows...and i tried to restore to factory default but it didnt work..and how would you know if the hard disc is the problem?.or if the d2d is corrupted?.pls help me..hope to here fr you..tyvm.alvinbulaong@yahoo.com,
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Are you using XP or Vista?
    Worldvet
    Novelist:
  • 148 Answers
I suppose u've windows vista huh ??
if yeah, try to grab a vista cd put it int the dvd tray, start ur machine & select boot from dvd rom
now select repair windows
that it
Posted on Sep 04, 2009
My Acer netbook aspire one just shut down on its own one day. Now it will only stay on for 25 seconds before turning off by itself completely! I tried going to setup - 25 sec. Regular boot -- 25 secs Safe...
You may have a Virus, try a factory restore. As you know, the Acer computers and those of other manufacturers are now delivered with a system of restoration installed in a hidden partition of your hard disk. This system launches out while pressing keys ALT+F10 simultaneously. And sometimes for various reasons this system ceases functioning.
The first cause often comes owing to the fact that function D2D Recovery is disable in the bios (menu principal).
The solution : enable the function and try to press keys ALT+F10 during the starting of the computer.
The second cause : in this case hidden partition PQSERVICE was erased or damaged, or you replaced the disc and in this case it is not present.
The solution : If you did not previously make a backup of your system by making an image disc. It will not be possible to use the D2D recovery. Your only hope will be to have in your possession Acer Recovery CD/DVD.
And the third causes : the Acer Master Boot Record (MBR)was damaged or replaced by non-Acer MBR. As long as partition PQSERVICE is present or that you can put the hand on the necessary Acer files you can reinstall the MBR of Acer.
The solution :
First method : on a functional Windows system:
1 disable the D2D recovery option of the bios.
2 open a Windows session with an account administrator.
3 Download, unzip and launch partedit32(registration required for download).
markymoo: ptedit32
4 Identify the Pqservice partition by its size (at the bottom of the partedit window there is a partition information box) it is a small sized partition approximately 2 to 6 Go.Once made change the type of your partition into 0C and save. Restart and open a session with an administrator account, you should be able to navigate to the PQservice partition. Seek these two files mbrwrdos.exe and rtmbr.bin once localised open a command prompt and launch this command mbrwrdos.exe install rtmbr.bin, this will install the Acer MBR. Close the command prompt window restart again Windows go into the bios and reactivate the D2D recovery. Now ALT+F10 should launch Acer recovery at the starting of the computer.
Second method : On a nonfunctional Windows system.
For that you must use a Linux distribution (for me Mandriva provided all the tools necessary).
1 Boot on the Mandriva install CD/DVD the boot menu will give you the possibility to repair or to restore the Windows boot loader.
2 If that is not enough launch an installation of linux(this will be an occasion to test this terrible OS) and choose LILO as boot loader(a boot menu that allow you to choose between several operating systems) once finished the installation. Restart your computer in the boot loader menu system you will have at least 2 Windows options the first generally point to PQservice choose it and you will boot directly into acer D2D recovery. __________________
Apr 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
Want to restore my Acer aspire 4720z!
From Acer direct
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 02, 2009 | Acer Aspire 4720 Notebook
Can you make restore disks?Does your PC boot up?If if does you ma by able to make restore disks to restore it to factory settings.If you are saying the key board doesn't work.You may need a new keyboard or possibly new motherboard
Jun 01, 2009 | Acer Aspire 4720 Notebook
Drivers for acer aspire 4720z
hi!we have read your problem.please dont worry, every problem has a solution.since you have stated that you have lost the driver details your system should have crashed.have you prepared a recovery dvd for your laptop.if yes you install the drivers from it.hope your problem is tackled.have a nice day!!!
May 23, 2009 | Computers & Internet
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
1 Boot to Windows XP
2 Press Alt + F10 to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Follow the instructions on screen to complete the process.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
May 05, 2009 | Computers & Internet
System recovery not working.
hello try this website http://www.thinktechno.com/2008/02/09/how-to-fix-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
lets try this first and if it don't work we will try something else
just copy and paste in your address barr
hope this helps bob
Mar 24, 2009 | Acer Aspire 9300-3716 Notebook
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Dec 24, 2008 | Acer Aspire 5630 Notebook
D2d recovery
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Jan 04, 2008 | Computers & Internet
D2d recovery
Send me an e-mail and I will send you the fix! If you can't downloadload it from the below link. I had the same problem. The mbr was replaced, you have to add RTMBR.BIN to the MBR and it will work again. As long as you can get on your desktop and run this bat file you will repair the D2D again. Took me an hour to learn what was wrong, It works 100% though.
I have the Aspire 5610Z with the 2GB 533 mhz memory Stock.
Link #1
http://rapidshare.com/files/64293596/Acer_MBR_F10_Repair.zip.html
Link #2
http://www.sendspace.com/file/ngd4ql
matrix@gainbroadband.com
Oct 16, 2007 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
