Question about HP LaserJet 4250n Printer
While giving print through manual, print is coming but after that it showing clear papaer path n again same print comming unlimited time through manual only,but if i close manual tray then smae print coming through normal tray.
    Problem Solver:
  • 13 Answers
Try opening all paths that could potentially be blocked by paper, not just that ones it states. Then unplug the device, wait 10 secs and plug it back it. Turn the device on and see if it works.
Posted on Mar 23, 2011
After any printing it say papaer jam. jam40
The paper feed path is not clear - remove any pieces of paper or debris if this doesn't help use dry paper because moisture can do this as well
Jun 25, 2015 | Office Equipment & Supplies
Wont print from fax memory
You may have a blocked paper sensor. Check the path the papaer would follow and located the sensors. Check them for dust or torn paper. The machine will not print until the jam error is cleared. If disconnected from power too long jobs in memory may be lost.
Aug 12, 2014 | Office Equipment & Supplies
Xerox 5030 jamming
clean all pick up rollrs and check all paper paths
Dec 12, 2013 | Xerox Office Equipment & Supplies
MY PRINTER STOPPED PRINTING AND GIVES A ERROR MESSAGE THAT THERE IS A MISFEED. I CAN NOT SEE THE PAPER FROM THE FRONT OR TOP ARE THERE ANY OTHER SOURCES THAT I CAN CHECK TO CLEAR THE MISFEED, IF THERE IS...
You need to consult your manual for all the paper paths that you may have missed.
Check all paths and go out and buy paper path cleaner, follow the instructions on the package and completely clean out the paper paths.
This should loosen or remove the stuck paper and get the printer printing again.
Please write back results (good or bad)
Mar 16, 2010 | Ricoh Aficio SP C231N All-In-One Laser...
Paper caught part way through printing
There is a line of sensors along the paper path, if any of these are obscured by even the smallest scrap of paper you will get the messasge, re check the paper path again it only needs a scrap of paper, also worth a try power off and unplug for 2 minutes to allow residual power to drain and then try power up and see if the message has cleared. Last but not least if you can spot any of the sensors give them a blow with some compressed air (paper dust build up) and retry a reboot
Sep 09, 2009 | Samsung ML 1610 Laser Printer
Xerox workcentre xd105f
It is entirely possible you have a small piece of paper that got ripped off somehow and it is now blocking the sensor leading the machine to think it has a paper jam.
Follow your jam clearance instructions again and pay close attention and rotate all movable parts in the jam area many times, then reboot the machine multiple times and allow the machine to completely come up before rebooting again, it may be necessary to reboot the machine 3 or 4 times to clear this error, each time following the jam clearance, if this doesn't resolve then you should have an expert take a look at the machine.
Oct 19, 2008 | Xerox WorkCentre M123 Copier
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Papaer jam
same thing happens to me
May 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP LaserJet 4250n Printer Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
