Question about LG SecurDisc 8x External Double-Layer DVD RW/CD-RW Super Multi Drive
My computer did not showing the cd drive incon. does not open the cd player cover in CPU.
    Master:
  • 525 Answers
You need to download the driver and install it.
Posted on Mar 23, 2011
When you click on computer it doesnt even show the icon for the dvd/cd player. I can insert a disk, and here it run; but nothing happens. I try to locate the program in the all programs file but it is like...
check the dvd/cd Rom connection inside cpu, if it does not work then
right click on my computer icon and select Manage->Device Manager->DVD/CD ROM drive
and the right click on that and select enable
it may help you
Jul 24, 2011 | Acer Computers & Internet
Can not scan
Look in Printers. If not shown, Reload DVD installation disc.
Check printers again once installation is complete, if still not showing you will have to manually install from DVD drive/ Computer screem.
Click on DVD drive that is showning Installation DVD, click/open icon, next screen should show contents, click setup incon, hopefully should then install.
Check Printers to make sure it has installed. Icon should be showing.
Nov 01, 2009 | Canon CanoScan 3200F Flatbed Scanner
I try to burn a cd using nero but the pc shows no drives....i have light scribe but it never worked ...i bought an external LG light scribe it worked twice but it quit too...now even when i go to My...
Hi ....
There could be many reason for this problem but the most common one is the hardware connection. Try and follow the below steps which might resolve your problem:
1) Open your CPU and remove all the cables connected to your CD Drive. Try and clean the drive off any dust and then plug it in again. Most of the time this resolve the issue.
2) If the above option does not work, just restart your computer and when your computers starts again, start pressing the "Del" key. this will open up the BIOS for your system. There search for avalibale devices. Make sure that your secondary drive is your CD drive and enable.
Try the above steps and if that does not resolve the problem, please reply back and we will move to the next step of troubleshooting your issue.
Cheers ....
Aug 07, 2009 | HP Computers & Internet
Install dvd rom and remove one of the cd rom's
hi! replacing cd room,open your cpu cover by two quick lock bolt at back side of your pc right side,show on figure w/ arrow where the quick lock bolt.c1c13bc.gifthen pull out cover and you'll cd rack inside your cpu as shown on figureba392e9.jpg release 2 lock screw,and pull out i.d.e cable on cd room terminal also the audio cable next to leftside if have one,next the front cover of cpu thats locking your cd room theres a cliff lock on side opposit of the fron cover lift it by flat screw driver slowly and careful it might broke,after cover was detouched,don't remove any wire connection on front cover,pull out your cd room replace by dvd rom and connect all what has been disconnect on cd room put back front cover,and connect pwer,audio and ide cable again then try to switch on your dvd rom is a plug and play you can install your dvd installer and follow wizard instruction and click finish...regards
Mar 27, 2009 | Dell Dimension 2350 PC Desktop
Why can I open my EXTERNAL CD PLAYER with Itunes?
i insert a cd into my labtop but i doesn't show on my itunes? HELP!!!
Nov 20, 2008 | Gateway (5501671) External 24x CD-ROM...
Audio cd and DVD
it is mainly due to two reasons
  1. your operating system don't detect your drive
  2. its data or power cable is not properly connected
In the first case, if you are using xp, open my computer, select control panel, click add new hardware icon
  1. read and do as follows
  2. the computer automatically detect your drive
  3. if it don't detect, using manual method and add the drive
In the second case, only do if you are little technical minded
  1. open cpu cover
  2. check the data and power cables attached to the drive
  3. refix the cable some time it may in loose contact
  4. replace cable if it may contact problem
Jan 20, 2008 | NEC ND-2510A DVD±RW Dual Layer Burner
Facing Problem
I have problem with my sansa.. whene i open it can't play and don't have anything in screen but it show the word: Local main imagr failed swith to recovery mode when starting up.and I cannot connect it to my pc anymore...how can i do...
Mar 09, 2007 | SanDisk Sansa c140 MP3 Player
LG SecurDisc 8x External Double-Layer DVD RW/CD-RW Super Multi Drive Logo
231 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
