Fujita air conditioner timer light flashing - Heating & Cooling
SOURCE: spilt air conditionerl
Hi deabreu5. I have a spare remote for the fujita split system model: KFR I also have the instruction booklet but no manual.
Mine lasted for 3 years and no cold air comes out anymore. I'm going to have a crack at fixing it myself somehow. But a spare remote came in the box so I'll sell it to you if you like.
email me.
Posted on Mar 23, 2008
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
  • 334 Answers
SOURCE: All lights are flashing including Pre Def, Timer,
Not sure the make and model of your equipment you have there but sounds to me like your control board is trying to tell you it is bad.
Posted on Jun 12, 2009
co7196
  • 3433 Answers
SOURCE: Samsung Air Conditioner will not turn back on after power Outage
Turn off the circuit breaker and wait 10 mins, then back on.
Turn off all units, wait a about 1/2 hr. See what that does. Also, Turn only one unit on at a time and let it run 5 min before turning on the secon and the same withe third. An what remote island might that be? Good Luck, Ned
Posted on Nov 11, 2009
SOURCE: Fujita V-Lec Air con
i need a window kit for my air con
Posted on Mar 25, 2011
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
HOW I CONNECte remote control to fujita air ASW-H18B4/HS
If it the correct remote control for the unit, point remote to unit and press power button this is normally followed by a beep to confirm unit has received command,
if this does not work please check battery's to ensure they are still fit for purpose
Dec 24, 2015 | Heating & Cooling
Mitsubishi air conditioner flashing timer light flashes twice
Switch the polarity of the control voltage...make sure it matches with the indoor & outdoor unit
Dec 18, 2013 | Mitsubishi Heating & Cooling
My fujita air conditioner has E2 fault and blows hot air
E-2. Indoor coil temp sensor defective. Replace it.
Dec 30, 2010 | Kenmore 75085 Air Conditioner
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
Jul 04, 2009 | Heating & Cooling
Spilt air conditionerl
email me.
Feb 03, 2008 | Heating & Cooling
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
