Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tv turns off 1 or 2 minutes after its turned on. has new lamp and filters are clean. i was told it is the power supply unit.
  • 36 Answers
Is the bulb properly secured as well as the lamp door? Sometimes if just the lamp is replaced into the old housing, it is easy to mix up the securing screws and have a longer one where it does not belong and as a result not allowing the housing to push in all the way.
If all is well, then I would suspect a bad ballast and/or bad power supply, but just buying a new one may be an expensive route. If you are able to, check them visually to see if any capacitors on these boards are bulged, blown or popped. If so, then there is the cause of your problem.
Be careful with the voltages and make sure the TV is unplugged before opening. TVs can still hold very high voltages even after unplugged, enough to kill a person, so don't open the TV if you are not comfortable with it. A good repairman should do this instead.
Posted on Mar 23, 2011
TV - Mitsubishi WD-62530 Will not power up unless first unplug from wall for approx. 15 minutes prior to turning it on or it will not power up at all).
Start with changing the capacitors that look bad on the PS board...I think you will find some that are bulged when you take the cover off, should be a easy and cheap fix
Oct 22, 2017 | Mitsubishi Televison & Video
I have an Optoma HD 8000 projector and while watching TV the lamp will turn off what can I do to repair the issue
if the lamp, lamp driver,power supply,Scaler Board and Formatter Board were good.
perhaps it is over temperature protection.
whether you checked with the air filter( dust filter) is clean or dirty?
Jul 02, 2014 | Optoma EP7155 DLP Projector
T.v.says lamp not working
If the display indicates then it is possible that the lamp has failed or that the Power to the lamp is cut off. You will need to check the status of the lamp and also the lamp connectors, the supply from the power.
Check to see if the cooling fan is clogged and so has reset the processor with a error. If so clean the filter to reset.
Jun 30, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Where is the lamp module located for a sony kdf 42we655?
Please read here: http://esupport.sony.com/US/perl/news-item.pl?mdl=KDF42WE655&news_id=84
From SONY:
If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the TV flashes, it is time to replace the lamp with a new one (not supplied).
Use only a replacement Sony XL-2100U or XL-2100 for your TV. Use of any other lamp may damage your LCD projection TV. Contact your Sony dealer for a replacement lamp.
Click here to download step-by-step directions for replacing your TV's lamp.
Note: Before replacing the lamp, turn the power off on the main unit. Wait several minutes, then unplug the power cord. (The cooling fan will continue to blow for about two minutes after turning the power off.)
Be sure to allow the lamp to cool down completely before removing it. The surface of the lamp remains extremely hot for at least 30 minutes after the power has been turned off.
Mar 10, 2011 | Sony KDF-42WE655 Television
Hitachi 50v710 turns off after about 1 minute
this is a very common problem with lcd and projection screen.. what is happening power supply are being over loaded manufacture did not think about the long term use of game and computer graphics which put out a higher amout of graphics which over works the power supply over time... but they did make them easily replaceable with in unit thier usally connect to main board with plug lamen terms...
if possible take unit apart locate wire from the socket for power cord follow wire to power supply disconnect.. socket maybe be directly attached to powersupply module either way detach locate part number on board call manufactuer order new one or take it to your local tv shop and have them replace items onboard that are bad
Jan 18, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
New Lamp turning off after 5 seconds
1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010
Apr 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power supply block/lamp issues
Try cleaning the air filter I have seen the same symptons as your describing, and cleaning the air filter corrected the problem.
Feb 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic
replace with a new aire filter or clean the air filter
vkm
Nov 23, 2007 | Panasonic PT-40LC12 40" Rear Projection...
DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Sep 18, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
