Question about GE Ovens
My display says bake F2 and bekow it says fav lt and won't clear
3 Suggested Answers
dblred
  • 68 Answers
SOURCE: f2 & f3 alert
thank you for the info. you need to replace the oven sensor. an F2 error is oven is to hot. an F3 error is a shorted or open oven sensor. the oven sensor is easy to change, and not very expensive. if you have further questions, let me know. shane
Posted on Aug 24, 2009
KevinWhite
  • 1902 Answers
SOURCE: Try to open "bake cycle".
Hello & Welcome to FixYa
F2 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. However, I believe it is the sensor as the problem is only with bottom oven. Please get back to me if you have any other questions.
Kevin
Posted on May 03, 2011
E-1 & F-5 come on after about a minute when attempting to use self cleaning. the micro switches work & the solenoid has been replaced. could it be the ERC ?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa
Oct 21, 2011 | Whirlpool GMC305PD Electric Single Oven
My whirlpool oven locke with F5 E1 what to do
Thanks
Oct 05, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My 2001 Kenmore oven error says ``E1 -F5-`` What does that mean
The E1- F5 error is a door lock error. The control has likely failed. Sometimes when you disconnect power to a range and reconnect it the electronic range control gets messed up.
You should disconnect power for 15 seconds and reconnect and see if that helps.
If it doesn't fix the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.Then turn off power again for 15 seconds and back on. Sometimes these work, but if the control has failed it won't make any difference.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Kenmore Ovens
F2 & f3 alert
Aug 24, 2009 | Ovens
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
Whirlpool accubake oven problem
Hi All,
I tired the delayed bake work around and it didn't help me.
So, being a trained scientist... I know just enough to be dangerous! Here's what I learned. (imitate me at your own risk. This thing is on a 220V circuit at 30A... you or someone else in your house could get badly killed if you do something wrong. You definitely want to send small children to the movies, or at least to bed before trying this!)
First, I turned the self-clean on for 60 seconds to see if both elemets were working. The broiler got bright red but the bake element didn't. The door unlocked as soon as I shut it off, so I could I touched an ice cube to a few insided parts to see how hot they were. The bottom of the oven was barely warm, but the baking element instantly melted and sizzled my ice cube.
Good enough for me: Both heating elements are working, so it must be a controller problem.
Next I turned the power off at circuit breaker, and double checked that the oven was dead. I pulled it out of the wall and removed the top sheet metal cover. Inside I found a red plastic envelope containing a "Tech Sheet". It has a schematic diagram, plus a table that explains the error codes and what to do about them. Be sure to read all the dire warnings and the bit about "For Service Technician's use only" before deciding that you are foolish enough to do anything with it. :-)
I undid and inspected the connector for the printed ribbon cable from the keypad to the controler circuit board. (I happen to know, being a scientist, that 90% of all problems in the universe are caused by bad contact) I didn't see anything obviously wrong, so I reassebled it carefully, making sure the ribbon was fully seated.
I then powered the thing up. It said PF for power failure. I pressed cancel for 5 seconds and it said F0E0 which means no pre-existing fault was detected.
I then pressed bake, and lo and behold the damn thing baked! :-)
I'm not certain it was bad contact, since the other 90% of the world's problems are caused by software. It's entirely possible that power cycling was this thing's idea of CTRL-ALT-DEL. Maybe someone can try flipping the breaker off for 10 minutes without taking anything apart, to see if that clears the problem?
I also have no idea how long this will stay fixed....
Has anyone tried calling Whirlpool? 1-866-698-2538, M-F, 8 am - 8 pm Local Market Time, Sat. 8:30 am - 5 pm Local Market Time, according to their website.
Stay tuned... if I'm not back, the thing is still baking... :-)
Apr 09, 2008 | Whirlpool RBS275PD Electric Single Oven
E1 and f5 error/Door locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
Ovens Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
