Question about Dynex DX-LCD37 TV
How do i get stronger signal - Dynex DX-LCD37 TV
  • 36 Answers
If you are referring to a cable signal on your tv set, then there are several ways, but first off, how do you know the signal is weak? Analog cable signals typically run at 30 to 40 percent while HD signals on the same line can be as high as 90%.
If your cable connections are firm and have no fray with good cable runs, and is not longer than needed, I would suggest calling the cable company tech support line for troubleshooting. It could be their error in an outside line.
Posted on Mar 23, 2011
How do i change channels on my router
You change the channel in the router's wireless setting.
This does not give you a stronger signal BUT you can select a different channel so you do not get interference with other wireless routers in your area that are broadcasting on the same channel.
Oct 15, 2012 | Cisco Linksys E1000 WirelessN Broadband...
37" LG flat screen is
With the onset of more and more TVs being hooked up to cable, TV manufacturers didn't need to make the tuners as sensitive because the signal from the Cable Co. was much stronger than the over the air signal. If the other TVs are older they may be just sensitive enough to lock onto the channel signals. You could ask your cable provider to check your available signal in the house to see if there is the proper amount of signal. Some channels can inherently be stronger and when "block converted" (put where the cable company wants the channels) all come thru but some are a bit clearer.
Aug 28, 2011 | LG 42LG30 42 in. LCD HDTV
I have a reasonably new 6120 but as of this morning people cannot hear me talk. I had the same problem with my N85 which stopped suddenly also.
If you used a same SIM card for those phones, I think its signal problem, when signal is low the connection will be disturbed sometime as no sound or cut suddenly during call conversation. Try to use different SIM card provider, with stronger signal will better, then put in these device. If the problem solved then its operator signal problem. The solution is change the SIM card.
But if you have try to change with other SIM card with stronger signal but people still can't hear you, then its microphone problem. You need to repair or replace your phone's microphone.
Hope this help and if this helpful RATE please.
Feb 03, 2011 | Nokia 6120
I have a Haier 7"
U get some picture on some channel but very weak signal and fade out and get Error codes on the tv screen?Yes,than buy a stronger Digital antena design to get better and stronger longer recieving signal ranges.
Dec 15, 2010 | Haier (PDTB7) 7 in. Portable Television
I have a Toshiba L25 laptop and a D-Lin Air DWL-650 wireless card. I'm not getting the best connection with the wireless card while my other computer has a much stronger signal. I'd like a recommendation...
im assuming its a cardbus adapter right? well that model is a wireless b signal, which isnt very strong, so any wireless g model should have a much stronger signal. it doesnt matter which one it is, as long as its wireless g, which most new cards are. hope this helps, goodluck
Jul 09, 2009 | Toshiba Satellite L25-S119 Notebook
I have a ACER TRAVEL-MATE 800LCI...with wi-fi wireless...sometimes the wireless works some times it doesnt...what kind of router or what ever will help me get a stronger signal from my house...please help...
put up the high level things then you get it very stronger signal now you not get be'coz of the signal low strenght is not there so he can't caught the signal so pls change it in the high level
Feb 22, 2009 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Stronger wireless card
There are no stronger or weaker cards (if your's is a 802.11g, which it most probably is unless its VERY old) ...you can try changing the channel on your wireless router...
Feb 17, 2009 | IBM ThinkPad X30 2672 Notebook
Stronger Wireless Signal with 2701HGB Router?
Netgear's web site has an excellent tutorial on how to do this. It involves turning off the DHCP on the Netgear, and linking the LAN prots of the two routers. There is no connection to the WAN port of the Netgear.
Here's the link http://kbserver.netgear.com/kb_web_files/n101236.asp
Carl
Jan 02, 2009 | 2wire 2700HG-B Router (2700HGB)
Get a stronger signal
You are pushing your luck at 70ft. You can probably get booster ariels for your router that can boost the output signal for approx £10.
Dec 13, 2008 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
Pixellation and sudio loss
The digital signal is sent over UHF(13-69) channels (unless you are in Chicago which uses VHF( 1-12). You will have signal loss during rain. You can get a stronger antenna and put on a pole outside your home which will help keep the signal stronger.
Jul 09, 2008 | Insignia Digital-to-Analog Converter for...
Dynex DX-LCD37 TV Logo
99 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
