I inherited this dual-deck amplifier from an uncle who has passed on. Unfortunately there is no manual with it anymore. The buttons on the tape decks don't depress except for the stop which immediately opens the tapedeck. There appears to be 3 settings on the left tapedeck which I can change but doesn't appear to make any difference. It sounds like the deck is constantly running except that none of the tape pins/sprockets turn. I suspect there may be a belt problem. There is a clicking sound which comes and goes but grows too an alarming volume unless I depress the Auto play button which the noise then immediately stops but nothing engages and the tape counter never advances. I'd like to see if it can still be used but I don't have a lot of money to put into it. I wouldn't mind trying to fix it however without the manual, I don't know where to even begin. How can I try and use this with my CD player and get the tape decks working again? If possible I'd like to run my DVD player through it as well. While I'd love to get the tape decks working, even if it can only be used as an amplifier/receiver, it would be worth it. Right now only the radio works but it has great sound. Thanks for any help you can offer so I can see if it will work.
    Sergeant:
  • 298 Answers
Hello
It's hard to provide advice without knowing make / model number. Many manufacturers have back issues of owners manuals on their websites - if not a Google search will often trawl one up
Lots of manufacturers used to put 'soft touch' buttons on cassette players - they don't actually push in (just wobble a bit) but work nonetheless. From your description it sounds like the drive belt has broken - alternatively it could be some worn cogs in the motor system, which might explain the clicking sound. Many years ago I had an AIWA tape deck that made a loud clicking when the tape counter got to 9999. Pressing the counter reset used to clear it.
You should be able to connect a CD or DVD player to it using the auxiliary sockets on the rear panel (assuming it has some). Any tape/ aux inputs should be the right impedance to work okay but a phono (record player) socket is unlikely to match. There will normally be a row of buttons (or perhaps a rotary dial) on the front to select input source.
Posted on Mar 23, 2011
How do I hook up a rsb11w dual tape deck to a technics sa450 receiver
Hi! This is normally relatively easy. You just connect the tuner output to the line input of the deck. Normally this is done with the amplifier where the tuner go to the tuner and the tape deck to its connections just line out to the cassette input and the cassette line out to the tape input of the amplifier
Oct 04, 2014 | Audio Players & Recorders
Technics rs-tr180 looking for repair manual
Look on Ebay. It will not be available new anymore. I might have it as well for a cost. Visit audioserviceclinic.com. Contact me there.
Sep 16, 2014 | Technics RS-BX501 Dual Cassette Deck
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Denon DRM710 cassette deck. I need to know the actual output impedance of this machine. Or the minimum load it should "see." Have lost my manual which has the specs. Thank you.
Just curious, what load are you having problems with? It's a cassette deck, not an amplifier. Most Line Level outputs work just fine with other devices' Line Level inputs.
Aug 21, 2011 | Denon DRM-555 Dual Cassette Deck
Left deck doesn't "play" anymore.
There is a mechanism problem in the Pinch Roller part of the deck.
It needs to be looked at by a Technician to correct.
Feb 24, 2011 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
I need to know how to record 1 tape onto another tape on a Technics rs tr-575 dual cassette deck
press the synchro start button, the tape deck should now go to REC PAUSE, press the SPEED button till you get the required recording speed then press the synchro start again and it should start to record from deck 1 to deck 2.
make sure the tabs at the top of the tape you want to record on are intact,
if not just put a bit of sticky tape over holes.
hope this helps?
Feb 05, 2010 | Technics RS-TR575 Single Dual Cassette...
My Sony dual tape deck does not record in stereo anymore.
Oxide deposits on heads can restrict audio transfer to tape. You may need to do a deep cleaning of record head. Depending on how much deposits are on heads may need no more than alchohol and Q-tip. Be sure to clean erase head and drive roller. Afterwards, try recording, then use headphones in jack on recorder to check for recording on both channels. If this works, problem is not in rest of equipment set up. If you still need help, email me
Apr 21, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Magnavox tape deck
APPLY A GOOD BRAND CONTACT CLEANER OVER THE BUTTON AND PRES IT MANY TIMES.
Jan 20, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
79 people viewed this question
 Grubhead
Grubhead
