Question about HP DC170B Keyboard
Control 2 does not produce the @ - HP DC170B Keyboard
  • 449 Answers
Should be Shift+2.
If that fails, make sure yor OS is set to the right region. Control Panel->Regional Settings->Keyboard should cover those settings.
What does it show instead of an @?
Posted on Mar 23, 2011
    Sergeant:
    Champion:
  • 234 Answers
To get the @ symbol you must use SHIFT and 2
Location of code p1137 on 01 alero
catalytic converter .
In order to control emissions, a catalytic converter converts any harmful exhaust emissions into harmless water vapor and carbon dioxide.
The powertrain control module (PCM) has the capability to monitor this process by using a rear-heated oxygen sensor (HO2S 2). The HO2S 2 , located in the exhaust stream past the catalytic converter, produces an output signal which indicates the storage capacity of the catalyst. This in turn indicates the catalysts ability to convert the exhaust emissions effectively. If the catalyst is functioning properly, the HO2S 2 signal will be far less active than the signal produced by the front oxygen sensor (O2S 1).
Feb 12, 2017 | 2001 Oldsmobile Alero
Tip
The blinking light problem ( clean light blinks 7 times) if the thermistor fails...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Pcm?
PCM= Powertrain Control Module. It is the brains of the car, it reads the sensor in put from all sensors including the cam shaft position sensor
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
May 14, 2014 | 2004 Toyota 4Runner
How do I read the graduations on the purifier control & what do the 1 or 2 red plate settings tell me?
The graduations are incremental for your ozone output for the purifier control. Generally, the machine can put out enough ozone to cover 3000 sq ft. (when the control is moved all the way to the right, about 5 o'clock.) Half way should be about 1500 sq ft or 12 o'clock. For general air cleansing, you should set the purifier control to produce enough ozone so you smell it when walking into the room (after home) for about 30 seconds. The ozone smell should disappear after that. If it lingers, you've got it set too high. For more severe odor control you can set it higher but remember that some of us are more sensitive to the odor no matter what the setting. It may need some adjustment based on your individual preferences.
I'm confused about the 'red plates' as you mentioned. The original machine comes w/ 2 ozone plates (made of glass) and doesn't produce ozone when one of the plates is removed. I'm guessing that the lines may tell you when you're engaging both plates to work, i.e. more ozone being produced & blown into the room or less only calling on one plate to produce ozone. If you send me a close up pic of the control panel I may be able to tell you more.
Feb 24, 2014 | Alpine Air XL-15 Air Purifier
My 1998 pontiac firebird service engine light came on and my OBD11 scanner produced 2 trouble codes PO125 ( insufficient coolant temperature for closed loop fuel control.the 3800V6 engine over heating and...
service the engine.. change oil ,filter plugs etc
did you clear the faults before each read
Diagnose Buick 3800 Engine
unusual code that
P0125 is the OBD-II generic code for the engine computer, or Engine Control Module (ECM), not detecting enough heat in the cooling system before the fuel management system can take control. The ECM has a predetermined value after you start your vehicle to expect a certain coolant temperature
P0125 OBD II Trouble Code Insufficient Coolant Temperature for Closed Loop...
ecm runs the engine cooling fans
3800V6 engine over heating and heater produces cold air
try these
EGR vale not working
overheating
inlet manifold gasket leaking
water pump fins corroded
soft radiator hoses
try a new radiator cap
internal heating
heater control tap stuck
directional actuator flaps stuck
Apr 16, 2017 | Cars & Trucks
Cruise control not working
This is probably all the diagnostics you need.
SET SWITCH
Check Continuity Between the O/V Terminal (F) and BE/BK Terminal (B) of Connector [17B]. Resistance Must Be InfinityOhms. Pressing SET/RESUME Switch to SET Should Produce a Reading of Less Than 0.5 Ohms. Are These Your Observations?
YES: STOP - Go to Test 7.4 (Part 2 of 2)
NO: FLHRC-I
Remove the Headlamp Assembly. Disconnect 6-Place Connector [22] and 4-Place Connector [159]. Measure Resistance Between O/W Wire on Connector [22B] and BE/BK Wire on Connector [159B]. Resistance Must Be Infinity Ohms. Pressing SET/RESUME Switch to SET Should Produce
YES: Locate and Repair Open on BE/BK Wire in Main Harness.
NO: Right Handlebar Switch Wiring Pinched or Damaged?
YES: Repair Wiring.
NO: Replace Cruise SET/RESUME Switch.
May 31, 2012 | 2003 Harley Davidson FLHRCI Road King...
P0977
Shift Solenoid B Control Circuit High
Areas to check:
  • Short in shift solenoid valve No. 2 circuit
  • Shift solenoid valve No. 2
  • ECM
  • Check the shift solenoid valve No. 2 when DTC P0976 and P0977 is output.
  • Check harness and connector between ECM and shift solenoid valve No. 1 or No. 2.
To check the Shift Solenoid Valve No. 2:
  1. Jack up the vehicle.
  2. Remove the oil pan.
  3. Remove the shift solenoid valve No. 1 or No. 2.
CHECK:
  1. Measure the resistance between the solenoid connector terminal and the body ground. Standard: 11 - 15 W at 20°C (68°F)
  2. Connect the battery positive lead to the solenoid connector terminal and the battery negative lead to the solenoid body ground. Standard: Solenoid operation noise is produced. If not, Replace solenoid valve. If the Solenoid operation noise is produced, Check and replace the ECM.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 03, 2011 | 2007 Toyota Corolla
My pc does not produce any sound when i am on or off the pc then have also no sond produce
1/ look on device manager sound is stall or not (right mouse click onmy computer click on device manager) 2/ type on run-"control" then click sound and click sound and divece and check setting.3/ reinstall sound softwere of board cd. if not correct, keep sound card to check on bord ()sound card isnot damage?
Jul 10, 2009 | M-Audio Audiophile 2496 Soundcard for...
Where can i get power producer 2 gold for free download please
Considering that Power Producer 2 Gold has been replaced by CyberLink's Power Producer 5, your best chance would be to see if someone on Craigslist might have it and will send it to you. As for getting it tonight, you'd have to have them send it via a courier service such as FedEx.
XMinusOne@gmail.com
Dec 10, 2008 | CyberLink PowerProducer 2 for PC
Amp powers on, but no sound is produced
a failed volume control potentiometer? it's possible.
Jun 04, 2007 | Sherwood RD-6108 Receiver
HP DC170B Keyboard Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
