Need code to use for the tivo remote - Televison & Video
  • 56 Answers
Push the TiVo button on the remote. Then push "Messages and Settings," followed by "Settings," and finally press "Remote Control." This will show you the three areas of the remote that are programmable. "TV Power, Volume and Mute," is one section. "AV Volume and Mute," is the second section. The final section is "TV Input."
Pick "TV Power, Volume, and Mute" by pushing right on the direction pad of the remote. This will open up a list of all the brand names of TV that exist. You will find most TV brands will be there.
Find your brand of television and select that option. If your brand is not there, simply go to the TiVo webpage and under "Setup and Support" you will find others who have experience this issue. There you will find a code for your TV. This happens sometimes when the TV is a lesser known brand.
Hold down the button you are programming (i.e. TV Power) for 5 seconds until the red light on top stays on. Then enter one of the codes on the screen.
Push the newly programmable button to test its functionality. If it does not work, repeat the steps with all the possible codes available. One of the codes will work.
Push "Live TV" at this point to watch television.
Use the manual which came with your TiVo in addition to this guide. In the front of the booklet will be a starter guide, which will lead you through the steps necessary to set up your remote for optimum use.
Posted on Mar 23, 2011
Rcr314wr need tivo series 2 code
RCA remote control have no set-up code/s to Tivo brand TVs. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 21, 2014 | RCA Televison & Video
Tivo remote
Try these and let me know:
006,007,010,011,013,016
027,033,035,043,066,087,089
Goodluck,
Dont forget to rate me as fixya..
Jan 06, 2008 | Tivo DirectTV Remote Remote Control
I NEED CODE FOR SUDDENLINK REMOTE
Hi - my name is Ashley, and I'm with Suddenlink. For Suddenlink remote control programming codes, please visit this site: http://www.urcsupport.com/html.php?page_id=289
If you have any other questions, please feel free to contact me directly: ashley-AT-suddenlink-DOT-com. Thanks!
Jun 26, 2012 | Televison & Video
I need code for RCA TV for Tivo remote
Go to http://support.tivo.com/app/answers/detail/a_id/294/kw/code%20search/c/105/r_id/100041 and under Programming TV Power, Volume and Mute, click on "show the steps".
Follow the instructions given.
The RCA remote codes are 0163, 0001, 0004, 0006, 0011, 0029, 0030, 0057, 0071, 0133, 0145, 0106, 0171, 0231, 0232, and 2210.
Try each of these codes one at a time (as per instructions) until you find one that works.
This link also gives instructions on what to do if none of the above codes work.
If this helps, please give a rating!
Oct 09, 2009 | Tivo Series2 TCD649080 Video Recorder
I need the remote (RC23) code for a series 2 Tivo Model TCD54008
if the remote is RC23, the tivo codes are 01442 & 01142. If you actually have a Rc16, then you can only control the tivo partially with code 20618 on either AV1 or AV2 device slots.
Jul 31, 2009 | Directv RC23 Remote Control
Programming my TiVo remote to control my Proview TV
  1. Cover the end of the TiVo remote control with your hand.
  2. Hold down the TiVo and TV POWER buttons simultaneously until the red light on the remote control remains on.
  3. Remove your hand from the end of the TiVo remote control.
  4. Enter code 0999.
After you enter the code, the red light will flash three times and then remain on.
  1. Press CHANNEL UP once every two seconds. This will test hundreds of codes, one by one.
IMPORTANT: Do not go any faster than this or you may skip over a code that works.
  1. If you press CHANNEL UP and your TV turns off, press ENTER to select the code. Press the TV POWER button to test the code. If your TV turns on, you have successfully programmed the remote
Jun 11, 2009 | Tivo Series 2 Remote Control
Remote code for a tivo remote
Ok I found it!  For the Proscan 32LB30Q from Costco, the 5-digit code for the Comcast remote is 00030, and the 4-digit code is 0030.
However, I still haven't found the code I need for the TiVo remote... but we're making progress.
Jan 31, 2009 | Proscan 32LA30Q Television
Need to program a directv philips series 2 remote
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
Dec 20, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
