Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
It won't on if bat if i charge it the battery will charged and the red light is on.
    Sergeant:
    Champion:
  • 205 Answers
It is ment be on until you remove the cable frome the estury of the source
Posted on Mar 24, 2011
Bat caddy battery will not charge ,red light blimks
since you have the red light blink and the battery is not getting charged,means that you have a problem with the alternator. Try to find a qualified technician to check the fault.
Feb 25, 2018 | Cars & Trucks
Does a light come on when charging and it's turn off
Normally it`s red when starts in charge and then turns green when full, if not your have problem named lost memory bat, use a flashlight to spend the rest of the battery, then try to plug in the appliance if want red continue charge until green light appear. Rather complicated but is actually very easy to do.
Nov 12, 2016 | Cameras
EB1214S battery won't charge
On your there are pins make sure they are making tight contact it could be that your charger is not charging the batteries to it's full extent
Nov 04, 2012 | Hitachi Gst Hitachi WH12DAF2 - 12V Impact...
Pentax Optio P80 battery won't charge all the way
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 01, 2012 | Pentax Cameras
Repair charge batteri
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jun 22, 2012 | Lenovo G550 Notebook
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes.\r\n ...
A 7.4 volt battery is two 3.7 volt Li-Po batteries in series. Battery has
expired, there is no saving it anymore in fact dangerous just having
around. Li-Po batteries are very sensitive to over charging and also
to being under charged, usually the device that's being operated by
this battery has a safety catch called a BLC (battery limit circut).
So battery won't drop below the safe voltage of about 20% of full
charge.
FYI Don't even mess with this battery anymore, replace it. When Li-Po
batteries blow up they have a VERY high temperature flash and can easily set a garage, house,ect on fire in a split second.
Have fun and be safe.
May 22, 2011 | xheli 9053 Outdoor Volitation Metal...
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
Softail harley duece 2004 did not want to start setting up for a month or six weeks, took my battery to be charged , put it back in on the way home the yellow charging light and red battery light came on ,
see what meter reads 12.6 v bat charged bike not running ..13.7 bike running.. check at battery conections ...Make sure conections clean at bat & at starter ground & pos. bolt on starter has been known to come loos check ground to frame also..start here ..for indepth A MUST have Manual ';';';
Apr 24, 2011 | 2003 Harley Davidson FXSTD Softail Deuce
Starter problem
If the starter is really spinning backwards, the battery must be in backwards. or the battery was charged incorrectly???
red cable goes to + positive,
black cable goes to -negative frame
You may need a new battery and hope none of the electrics has been damaged
May 02, 2010 | 1996 Suzuki GSX 750 F (Katana)
Red bat light on flashing pwr sply pluged in bat status says 9%/214hrs this does not decrease and bat does not seem to charge
Your power supplies voltage is incorect and the adapter should be replaced. It may be supplying enough power to run the system but not to charge. Cheap replacements on ebay. Good Luck.
Nov 24, 2009 | Dell Latitude D610 Notebook
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
