Question about Sony CDX-GT510 CD Player
I have a snoy cd player that i hooked up with a wiring harness i bought from the store. I lost my old one. They told me that the harness will work but after connecting everything the cd player won't work. It has power and will take a cd and eject the cd but for some reason the display won't work. The wiring harness didn't have any illumination wires on it and i am not sure if i needed them. The display shows five red lines across it when i try to turn it on
  • 61 Answers
You may need the ilumination, pleas google your car model year and brand and the words "stereo wiring diagrams" and you'll may find the correct wire distribution of your car
Posted on Mar 23, 2011
SOURCE:
I lost the manual to install my stereo pioneer DEH - 23ub
go to store that sells car decks and look for a wiring harness for ur car its about $7 mybe and prettymuch match the colors on ur deck to the harness and then pull ur old deck out and pull the harness from the back the back of that deck and plug that into the wire harness u just bought and hook up the antenna for radio andput the deck into the dash the wire harness should also come with so directions too just in case
Apr 16, 2011 | Pioneer DEH-P2900MP CD Receiver...
I just hooked up a pioneer deh-5100ub stereo in my 2004 dodge ram 1500 pick-up using a store bought wiring harness but I cannot get any sound from my speakers now.
Does you truck say Infinity anywhere on a door panel or such? If so you need to make sure that the blue wire from the store bought wiring harness is connected to the amp turn on from the pioneer.
Mar 02, 2010 | Pioneer DEH-P5100UB Car CD/ MP3 Player
Speakers don't work
If you had followed the directions correctly and the old speakers worked as well, take the new radio back for exchange
Jan 18, 2010 | 1990 Nissan Maxima
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
Wiring in a new car deck
The easiest and most efficient way to hook up your old radio harness to a new head is to use a harness adapter that is made for your vehicle.
If you have not cut off the old plug that went into the old radio then it would be a simple matter of plugging the adapter harness into the old plug and color matching the wires from the adapter to the new head wires, which will be the same colors.
If you go on line to - Installer.com you probably will find the correct adapter for your vehicle. There are other on-line stores that deal with adapters, as well.
If the old plug was cut, it may be possible to splice the plug back to the original wires, then it's a matter of plugging the adapter plug into it.
Hope this helps...
Jul 13, 2009 | JVC KD-S5050 CD Player
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Problems with car audio
you should plug in the new harness and meter the wires to make sure there is power on two of the wires one will always be powered for memory the other should be powered when ignition is on if both test ok then check the in line fuse links on the radio wire harness I hope this helps good luck....
Jan 10, 2009 | Sony Xplod CD Player w/MP3 Playback...
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
Clarion vrx755vd no wire
Hi
its dificult to wiring your unit for a novice man! that What is call Convertion! If you have experience in electronics maybe i can tell to you how to wiring that in properly!
thanks!
Jun 18, 2008 | Clarion VRX935VD Car DVD Player
Kenwood cd player to an 05 jeep - no sound
Hook the Blue/white striped wire to the power antena lead of the jeep (blue) to turn on the factory amp
Don
Apr 17, 2008 | Kenwood KDC-135 CD Player
Sony CDX-GT510 CD Player Logo
254 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
