Question about Nintendo Wii Console
How do I order another sensor assembly, complete with cable and console plug? My sensor was working just fine until the sensor cable became brittle from the heat of the TV.
    Problem Solver:
  • 13 Answers
You can buy them at Amazon. This one has good ratings and is cheap.
Sensor Bar.
Posted on Mar 23, 2011
  • 32 Answers
They are available on Amazon.com. Amazon has many payment options and excellent customer service.
http://www.amazon.com/Replacement-Wired-Remote-Sensor-Nintendo-Wii/dp/B0018QOWEU
    Novelist:
  • 102 Answers
You can probably find replacement Wii Sensor Bars at any major video game retailer (Walmart, Gamestop, etc)
You can also find them on numerous websites. For example:
Amazon
Gamestop
There are also wireless versions of it, if that's your thing. Here's one on Amazon.
Wireless would probably be best since the heat messed up the cable on the wired one, but that's just my opinion.
Hope this helped!
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
98 honda accord center console controls for the fan, heater and AC no longer have power
You must have obviously checked that all fuses are in working order. the A/C subpanel has just one connector. Either the cable leading to it broke, or the connector became disengaged. This is almost impossible to happen, unless the center console was taken out to service the radio or something. Taking down the center console, in order to reach the back end of the A/C subpanel is a tad complicated, but you must do it in order to inspect the connections. Look elsewhere here on fixya for disassemble instructions.
Jun 25, 2011 | 1998 Honda Accord
I had it working on hdmi cable but i don't have a tv here that supports hdmi so i am trying to use the regular 3 hole plugs and theres no picture comming up but the system powers up fine any ideas
You have to switch it to composite from HD mode. You can try starting your console in safe mode.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
My ps3 worked fine. Powered off completely one day and turned it on again to find a black screen. tried doing the beeps reset and it doesn't work. The first beep turns it on and then 3 sec later another...
Here is the proper procedure for Safe Mode.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their untill you console turns off then take you finger off the sensor.
Good Luck!
Feb 19, 2011 | Video Game Consoles & Games
My whirlpool cabrio top loader waher keeps giving me the f1 signal. i have unpluged it, hit cancel restart and still same thing. once i finally get it to go, it washes fine. can you please help me/ thanks,...
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting the F1 error message everytime I use my washer with all cycles. I keep hitting pause then restart until it finally completes but sometimes it may restart 5 or more times to complete rinse/spin...
Jun 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Hand Sensors Don't Work
If hand sensors are on are on a bar that was installed during assembly, the wires that connects the sensor to the console probably didn't get plug in during assembly. To check this, see if the part with the sensors can be removed. If so the wire conection is usually at the point where you connect the sensor bar or handle to the machine. If they are made onto the console then you will probably have to remove the back of console. Pass this point just a visual check for obvious disconnection only. In not obvious don't touch anything else call an expert.
Nov 17, 2009 | Life Fitness T3 Treadmill with Advanced...
X Box 360 No lights and controllers wont connect
After the RROD became a major issue,Microsoft extended the warranty to three years..hope u get it quick!and make sure u know the RROD properly!!
Dec 08, 2008 | Microsoft Xbox 360 Console
How to Reset wii parental controls everytime any time
my nintendo wii after loading quantum of solace 007, it automatic updating. after that it makes my nintendo wii setting not work, it still asking for internet connection. Please send me email to rama.anggara@gmail.com if you have any suggestion. thanks so much!!
Oct 29, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
81 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
