Question about DeLonghi Heating & Cooling
My air conditioner keeps turning off every few minutes
4 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Posted on Jan 04, 2008
  • 4 Answers
SOURCE: air conditioner turns on then after a few minutes
check you filter then you evaporator coil inside your furnance .....if that doesn't work your outside unit's coil needs to be cleaned
Posted on Jun 26, 2009
luker711
  • 91 Answers
SOURCE: My home's Air Conditioner shuts off and on until reach temperatur
You have some issues that probably need to be addressed by a Certified Tech asap. There's an off chance that it could be just thermostat related. If you feel confident on doing what I'm about to instruct go ahead and try it.If you turn off electricity to your unit(should be marked as A|C or furnace or the like if you have the unit on and turn off at the panel it's easier to locate) you can take the cover off your thermostat and you will find various wires. Unscrew the R, Y, and G wires(if they;re not colored red yellow green make a diagram as to which goes where) and twist them together, Then turn electric back onto unit. If the unit runs normally as it should, then you have a thermostat problem and need to get a new one right away. Remember you unit is worth $2,000 to $6000 don't let and electrical malfunction compromise the value, if it.s not the thermostat get someone qualified to look at it. Leave it off til they get there. Good Luck
Posted on Jul 16, 2009
My air conditioner keeps shutting off
It could be low in gas, needs servicing by a trained technician
Aug 05, 2014 | Windchaser PAC8 Air Conditioner
Why does my Furnace exhaust cycle on and off while air conditioner is running?
Check all of your thermostat wiring between your furnace and thermostat. Check connections. Check for nicked wires.
May 28, 2014 | Heating & Cooling
Air conditioner fan wont start
change run capacirotor of outdoor fan motor.
Jan 07, 2014 | LG LSC121PMA Split System Air Conditioner
Kenmore 12000 btu turns on fine but after a few minutes fans shut off and compressor keeps running this is a heat and air model
First replace fan capacitor and try, if not, bearings worn out in your fan motor. Replace bearings or motor with new capacitor.
Jan 14, 2011 | Kenmore 76081 Wall/Window Air Conditioner
I can,t keep it running. I don't have instructions. do you have start up instructions. It shuts off after a few minutes.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Oct 03, 2010 | Heating & Cooling
The air conditioner kicks off every few minutes on very hot days
Check the condenser coil, it sounds like it's dirty. If not then the condenser motor may be bad, running slow or not running at all.
Jun 29, 2010 | Whirlpool ACC108PS Air Conditioner
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
Heating & Cooling Logo
104 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
