Question about The First Years Ignite Stroller City Chic
I put the front wheels on wrong is there any way to take them back off without ruining them?
How to replace front wheel studs on 2011 Kia Forte
If you can find just the studs and not have to buy the whole hub assembly, screw a lug nut on flush to the stud and drive it out with a hammer, make sure its in a position to have room on the back side. Put in new stud and with a few spacers tighten a lug nut to seat it.
Aug 15, 2014 | Cars & Trucks
I popped a wheelie camed down REALLY hard on front ...now it will not run properly...not starting (like battery dead)... when it does... wont stay started What could be the problem?
Motorcycle batteries are actually rather fragile. You probably did one of two things. Either the battery acid spilled over from cell to cell and ruined it, or the shock of coming down hard dislodged one or more of the plates, which would also ruin it. With no battery operating, no starting. If you bump start it, (either rolling downhill and popping the clutch or by pushing it to do the same thing, although you usually have to jump on the bike after getting it going and dumping the clutch at the moment you come down on the seat. do only in an emergency) you might get it started, but you are now running without the battery's "buffering" of the alternator's output, and I would not recommend it. Solution, get a new battery. You might also get the front forks checked, I have seen fork tubes that were bent, triple trees cracked, damaged axles and wheels damaged. Any of those can happen with even one hard wheelie. Its hard enough with only two wheels, you had to try with one? Just kidding, I have been know to try a couple, but in an abandoned parking lot! You can't steer and you can't stop until you get the front end back on the ground, you haven't seen it all until you see a Harley on its back wheel. I even did a few "stoppies" (hard front braking and lean forward and you can get the rear wheel to lift, need dual disc front brakes usually). Fun for a while, but not my cup of tea for doing it more than for a few minutes. Had to see if my modified HD could do it and it could. Scared the ##### out of me to put it mildly.
Sep 04, 2013 | 2009 kawasaki Ninja 650R
Yamaha 600 diversion front wheel bearing
either your front wheel bearings are not fully seated into the rim, Or You may have got a set of bearings that are the wrong thickness "width" .
Nov 10, 2012 | 1999 Yamaha XJ 600 Diversion S-N
Help me please !!!!! timing belt issues!!!
check for any sensors left disconnected ,if this is a 94 then the chances are the sensor is on the front pulley and it hasnt been re-connected ,also it may have a cam sensor .get the person who changed the pump back to put it right why did you let them leave without the car starting
Apr 14, 2012 | Mitsubishi Cars & Trucks
Front end has a grumbling noise, suspect front wheel bearings
your rotors are grinding because have no brake pad left so they are metal to metal ruining the rotors the longer you drive without repairs
Oct 18, 2010 | 2000 GMC Sierra
How to put the timing belt back into my car a 1994 Murcury Tracer. The timing belt had came off the car and I had to go new timing belt to put back into the car and I have no idea how to put a timing belt...
if you have no idea then this is not something you are going to wanna attempt. It is a very delicate proccess. And if you get it wrong you will ruin your engine. By ruin i mean blow it up. The engine has to be exactly in time or it will ruin your valves
Aug 21, 2010 | 1994 Mercury Tracer
What is the front wheel bearing torque on a 2002 gmc sierra
Torgue the bearing to 30-40 ft lbs,to seat the bearing, then back it out. Now tighten it by hand just enough to hold the bearing in place. Spin the wheel by hand as you snug it back up. You don't want to over-tighten it, this would cause friction, making it harder for the wheel to spin. Not too loose either though. Just enough so there's no "play" when you try to wiggle the wheel. Now you're ready to put the cotter pin back. Somebody had posted an answer with an extremely high torgue spec. If you already took that advice, you probably ruined you're bearing by now.
Nov 11, 2009 | 2002 GMC Sierra
How do you remove front wheel bearing
is this front wheel? rear wheel? or 4 wheel drive? if you have front wheel drive or 4 wheel drive you will need to take the tire off and get the center cap off with cotter pin on most vehicles. then put the tire back on without its center cap. then put the vehicle back on the ground. then use required socket with an extention and breaker bar to put through the rim to loosen center hub bolt about a quarter turn. just enough to break it loose. then take the tire back off to finish the job. remove the brake caliper and rotor then center nut on hub bearing. there should be 3 bolts from the inside holding hub bearing on. on rear wheel only you won't need to take the tire off and on.
Oct 08, 2009 | 2000 Honda CR-V
Bugaboo frog stroller- front small wheels put on wrong way. how do I get them out without breaking them?
get flash light and butter knife... shine light through back of where you have your wheels... use knife to press tab back and pull on wheel.
Jun 03, 2009 | Bugaboo Frog - Aubergine Stroller
Brake disc scrapeing on brake pads
Hi ...... I dont have experience of this particular model but something is def'ly wrong with the set-up as you have it.Take it apart and apply the brake with the disc in the caliper (support wheel on blocks/bricks whatever) and the put spindle through the wheel. This will show you the wheel 'centred' and give an indication which spacers you have go where. Only other thing you might have done is placed the speedo drive into the wheel without engaging correctly. Disconect at the clock/speedo and whilst spinning the wheel look to see if the cable is turning OK.
Good Luck ........... any problems let us know.
Dec 29, 2008 | 1990 Aprilia Red Rose
The First Years Ignite Stroller City Chic Logo
175 people viewed this question
Top The First Years Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a The First Years Baby Gear Expert? Answer questions, earn points and help others
