Question about RCA Televison & Video
I bought a new converter box when technician said no signal meant I neede a new one. I connected new one and it still says no signal and I lcan't change channels
  • 61 Answers
Did you properly connect it to an antenna? sorry for the dumb question
Posted on Mar 23, 2011
I have a Toshiba older TV that doesn't have HD digital converter box I bought a leaf ultimate antenna do I still need to use the converter box with this new antenna
if the tv does not have a built in hd digital tuner you need a Hd digital converter to analogue converter. What you need to be careful about is the available inputs on the TV if it only has AV in then you need a converter that transmits out RCA video or an analogue tv channel on RF the tv can tune into. Some of the new converters have HDMI out so if TV does not have HDMI input it won't connect. The antenna would go into the converter. Not sure how much signal you need you may need an rf amplifier if the signal is poor in your area.
Jun 01, 2015 | Toshiba Televison & Video
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
How/where do I connect tivax digital convert to my loewe Planus
The converter box has multiple ways to connect,but its really meant to convert a digital signal to analog. That's why the output channel for the converter is usually either channel 2 3 or 4 and you change the channel on the box rather than the tv. The box can be hooked up to the tuner which is the metal connector for antennas or cable. You can also use the composite hook ups as well (red and white audio, yellow video ) Just check which input on the tv your plugging them into so you know which to select for viewing. Signal out of the converter box,to video (av) in on the tv and you're good to go.
Nov 01, 2009 | Loewe Concept L32 Platinum 32 in. LCD TV
New tv. won't work
Press the input button and select where you have the satellite plugged in.
Aug 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
No Signal
Make sure you have a good connection from the antenna to the converter box. Set your TV to channel 3 or 4.
The converter won't improve reception in any way, and it's possible you might need to relocate your antenna or get an exterior antenna hooked up to improve the signal strength.
If you have enough antenna cable, and you're only using rabbit ears, hang them out the window or up on a curtain rod and see if that improves things.
Some people have good luck with the new digital style set-top antennas. I think you'll have best luck, though, with an old roof-top antenna that's set up to feed your converter.
Best of luck to you!
Apr 10, 2009 | Insignia Digital-to-Analog Converter for...
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Televison & Video Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
