Question about D-Link DES-1026G 24-Port Ethernet Switch (079006924654)
How to find the mac address of d link des 1026g gigabit switch? I want the mac address to configure a network connection in linux??
  • 2,460 Answers
Is this a trick question? A DES-1026G is an UNMANAGED switch. I think that means it is transparent to the network and has no MAC address.
Carl
Posted on Mar 23, 2011
D'Link DES-1016A
assign them an IP address each, making sure the addresses are all different and consecutive, make sure the subnet mask is the same on all machines, the switch will work right out of the box.
Jun 07, 2012 | D-Link Computers & Internet
I have purchased a D-Link DES 1026G unmanaged switch but have no idea how to go about setting it up. We have 8 computers running windows xp a Iburst broadband internet connection and two printers ( 1x HP...
hi,
well depending on any other items in you network. it appears that you would conect one of the 2 gig(on right side) ports to your router(iburst).and all other systems directly to this switch 24 ports. considering this is unmanaged there is no config. it works flat out across the network segment created by your Iburst router.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Jul 19, 2011 | D-Link DES-1026G 24-Port Ethernet Switch...
D link des 800d switch configure ip addess for 2 computers on a network
D-Link DES-1008D 8-Port Ethernet switch is unmanaged switch which can only support 10/100 MBPS.The DES-1008D is a passive switch which means there is no way to configure the ip address and no need to.
Jun 30, 2011 | D-Link DES-1008D 8-Port Ethernet Switch...
How to configure ip address to DES-1008D 8-Ports?
May 04, 2011 | D-Link DES-1008D 8-Port Ethernet Switch...
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
I have forgot the password their is no reset bu...
Dlink has stopped production and support on that particular product. Really need to dive in self and figureout resetting and configuration
This looks it can be done from console.
To go into console you need console cable connected to your switch and computer.
Start hyper terminal, by going to start-run- type "hypertrm" hit enter.
For more information refer to below manual
http://www.cybernates.com/des3326sr.pdf
User manual for your reference
ftp://ftp.dlink.com/Switch/des3326SRM/Manual/des3326SRM_Manual_402B13.zip
Hope this helps.
May 21, 2010 | D-Link DES 3326 (DES-3326) Networking...
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
Spare fan 40x40mm how much ? Volts for D-Link DES-1026G
I believe the fans in the back run at a standard 5 volts. You could most likely substitute with a small laptop or PC fan.
Dec 04, 2009 | D-Link DES-1026G 24-Port Ethernet Switch...
I am not able creat Lan computer with D-Link Dir-300 wireless G router. We require lan for 4 Computers. One node is working with Wire less and other with cables. Previously I used D. Link Router
connect your wireless router with swithch with straight cabvle of lan. bt first connect your wifi router with any computerr so u can configure it as dhcp enabled.
Jan 03, 2009 | D-Link DES-3052P 48-Port 10/100 Managed...
D-Link DES-1026G 24-Port Ethernet Switch (079006924654) Logo
594 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
