My washing machine is overfilling with water - Washing Machines
  • Anonymous Mar 25, 2009
    Washing machine is overfilling. Becomes a fish tank.
  • 550 Answers
The solution is to fix the water level sensor, which is a little different in every model
Generically it is a tube from the bottom of the tub to a pressure sensor in the control console. Often the tube comes off the sensor.
As a first check, open the console and make sure the sensor tube is attached.
If this isnt the solution add make and model to your question and try again
Posted on Aug 03, 2008
The washing machine is overfilling the water?
A defect in the water-inlet valve .The water inlet valve is the device which allows the water in the machine when the machine is turned on.but if the valve is faulty then it will not stop water to the machine even when its turned the washing machine overfills with water.
The valve is located at the back of the washer, and it will have water hoses hooked up to the back of it. Shut off the supply of water to your washer. Disconnect both hoses at the back of the washer. Before removing or checking the need to replace the valve if its faulty. If the water -inlet valve is checked OK.Then the other possibility to check out is the Water-level switch.The Water-level switch is the part that senses the water in the tub.if the water reaches to its required command the water supply to stop.But if the switch is faulty then it will not sense the water and water keeps on filling and at last water overfills due to Water-level switch not working properly. The Water-level switch is located at the bottom of the outer tub in the washing machine. This will help.Thanks.
on Mar 18, 2010 | Washing Machines
My LG model WM1812CW washing machine is leaking water and says FE in the display
problem with the inlet valve or oppressor switch,because of the overfilling water, sawing FE ERROR
Jan 26, 2014 | LG Washing Machines
What eroor8 in weat point washing machine
Error 8 Washing machine has detected an
overfill situation This error code can be caused by
overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as
the pressure sensor will falsely read
that there is too much water in the
washing machine. Also check the pressure sensor and
that the machine has not actually
overfilled with water. Check for overfoaming or over
soaping Check the air chamber and the
pressure switch hose Check water level sensor Check wiring to water pressure
sensor Check connections to water level
sensor Check main electronic controller
Jul 14, 2013 | Washing Machines
The water is overfill
Overfilling is caused when either the water inlet valve or water level switch is bad. When any of these parts goes bad it won't shut off the water and so cause overfilling. Hope this helps...please post back for further assistance.
Jan 21, 2011 | Whirlpool AWZ410 Front Load Washer/Dryer
Water didnt shut off at medium load. overfilled
Sonds like faulty pressure swith/ or hole in air pipe feeding switch/or chamber blocked feeding air hose..Good luck
Sep 30, 2009 | Washing Machines
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Washing machine overfills with water at start up after two years in use.
If the washing machine operates and cycles correctly, and only problem is overfills, then you have a bad water level switch or a bad membrane sensor (water level sensor).
If instead the machine get stuck on filling, and does not stop even if you advance timer, then the inlet valve is stuck on open, or the control board is faulty.
If machine is only two years old, call manufacturer and complain, even id limited warranty is one year, they may cover the part cost the same if they decide this was a factory defect (if it is inlet valve) coming up after two years.
Mar 17, 2009 | Whirlpool Washing Machines
Washing machine overfilling
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your washing machine overfilling.
please give us more information .
What is the manufacturer and model number of your problem washer?
Thank you
Sep 29, 2008 | Washing Machines
Suspecting the water level switch is the first step since this device controls starting operations. There is also a possiblity that the water level pressure hose has come off the tub. Make sure this plastic line is attached before replacing the level switch.
Jan 13, 2008 | Washing Machines
Washing Machines Logo
435 people viewed this question
Top Washing Machines Experts
