Question about Kenmore Dishwashers
The cycle will run and fill with water and then shut off. the sprayer wont pop up and spray water
    Problem Solver:
  • 5 Answers
Sounds like your dishwasher is on it's last wash cycle the motor that pushes up the sprayer is out time to get another one
Posted on Mar 23, 2011
My GE Dishwasher model GSD1300N10WW doesn't clean dishes,glasses and silverware. Everything has a film on it. I think the tower sprayer might not be popping up but cannot tell.water does spray from the...
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Maytag Dishwasher
White film on glasses and plates; I have cleaned tubes and nothing is blocking. is it possible that it is too much calcium/deposits; or a ring/gasket in the bottom sprayer that pre vents the water form...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Jan 01, 2011 | Whirlpool Dishwashers
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
DW fills and empties, but, in between the sprayer never comes on. There is absolutely no sound as the timer goes through the spray/wash cycle.
start the unit and open the door after abt 3 mins and look for water inside.if water is there and u dont hear water spray sound when running but only a low humming sound the motor is bad.if there is no water then chk for anything stuck under the water float.if that is ok then there is problem with fill valve.
Aug 17, 2009 | Dishwashers
Disherwasher fills with water but will not spray
Mine did the same thing; cycled through without any actual washing by the spray arms. pulled the sump and found a piece of broken glass was jamming the impeller. Might have been able to remove this glass by removing the volute cover and exposing the impeller while the sump was still in the machine, but that's hindsight.
Jul 25, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Sprayers Will not work.
so what is the problem fills but wont spray
Dec 10, 2008 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher not cleaning/water sprayers not spraying it appears
I had the same thing recently. Everything appeared fine mechanically, but no water would spray. I inspected the bottom arm as closely as possible and actually found a half melted clear plastic straw inside of it. 30 minutes, tweezers and a small pick eventually got it out and all is fine.
Sep 14, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
61 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
