Question about JVC Cameras
Gud am! i have a videocam jvcvictor F1.2 i want to consult about the battery because after charging it it will only run for about 10 minutes and its already used up i intended to consult the nearest jvc service center . my location is sta. cruz mla. pls. reply thnkx
  • 56 Answers
Hello,it sounds like a battery problem you need to get jvc to change the batteries to a higher usage rate. Most rechargeable batteries dont charge to their full capabilities. Also bear in mind that a camcorder drains a lot of power out of these batteries. Sometimes if you let the batteries go completely flat they will charge better the next time as they have less resistance.
Posted on Mar 23, 2011
2000 aratic cat 400 4x4 runs 5-10 min. if the battery is charged, but then stumbles and stalls. checked when running and the battery voltage keeps dropping till it quits. what can it be?
Charging system is not providing necessary current and battery is getting draqined. Need to diagnose charging system and do a complete battery check at the same time.
May 30, 2014 | Harley Davidson FLHT Electra Glide...
My battery charges but only lasts about 20 minutes once it says it is fully charged. Just purchsed a new battery thinking it was old (laptop is about 3 years old) and the same thing happens.
From what you describe and assuming the new battery was "new", I'd say you have an internal short which is draining the battery over a short period of time. I'd also investigate the accuracy of the battery charge indicator. Download this free utility which will give you a more accurate picture of your battery:
http://www.mioplanet.com/products/batterymeter/
I'm assuming you gave the battery a "commissioning charge" when you bought and used it?
If not, this is something you should do with all new LI batteries. This bit is reproduced from a website that sells batteries for the Toshiba satellite series:
"2. The new Toshiba Satellite a205-s4777 battery pack needs to be circled (fully discharged and recharged) three to five times to reach its optimum performance.
3. Toshiba Satellite a205-s4777 battery will undergo self-discharging when left unused for a long period of time. Thus, it should always be stored in a fully charged state and kept in a cool, dry and clean place.
4. It is normal if the new Toshiba Satellite a205-s4777 battery gets warm when being charged or used. However, please pay special attention if the battery pack becomes excessively hot. This may indicate there is a problem with the charging circuit of the electronic device. Please consult a qualified technician if necessary.
5. To maintain the optimum performance of Toshiba Satellite a205-s4777 battery pack, it is highly recommended to circle (fully discharging and recharging) it at least once a month.
6. New batteries are hard to be charged. Sometimes, your electronic device may indicate a fully charged condition about 10 to 15 minutes when Toshiba Satellite a205-s4777 battery pack is being charged for the first time. When this happens, remove the battery pack and let it cool down for about 10 to 15 minutes then repeat the charging procedure. Sometimes, the new Satellite a205-s4777 battery will suddenly refuse to be charged. If this happens, a suggested solution is trying to remove the battery from the device and insert it again. "
Jul 21, 2011 | Toshiba Satellite A205-S4777 Notebook
My worx will not stay charged... the charger goes green after about 10 minutes and only runs for about 5 minutes...
it sounds like the battery has seen better days. a battery will get a "memory" and after while it could fully charged as far as the charger know but only hold a little charge. with the advices in batteries they shouldn't do this but they all do wear out of time. I would get a new battery, and everything should be just fine. With the any new rechargeable battery you want to make sure that you charge it completely and drain it the whole way before recharging.
Best of luck
Mark
Jun 23, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
2003 chev suburban.battery went dead.replaced battery,now it wont crank and security light blinks
I have ran into this problem many times. Insert the key, and turn it to run. After 10 minutes the security lamp should go out. Turn the key off, and then back to run and let it sit another 10 minutes until the security lamp goes out again. Now repeat this one more time for another 10 minutes until the lamp goes out again. This should be a total of 30 minutes so make sure your battery is fully charged when you start the procedure. After the third time and the lamp going out you should be able to restart the vehicle.
Jan 17, 2010 | 2003 Chevrolet Suburban 1500
Lenovo n100 is 10 minut after power off.
If you are running on battery power and it powers off, then the battery is not fully charged or the battery is worn out or faulty.
Rechargeable batteries have a finite number of charge and discharge cycles and after 2 or more years they will lose its charge capacity until it will not charge at all.
A new battery will solve your problem provided the charging circuit in the laptop is OK.
Sep 26, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Car will start after a jump, but doesnt last.
brain needs to be reset job for agent it is tripped.
Aug 24, 2009 | 1997 Ford Explorer AWD
Peg Perego 800 Twin ATV - Only runs for 10 - 15 minutes at a time
Go ahead and charge it for 24 hrs. If it still does not run contact the repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.htmlthese guys (and gals) help me out all the time.
May 31, 2009 | Polaris 800 Twin Sportsman Ride on Toy
Videocam charging and keeping moisture out
The internal charger in the camcorder has sensors to prevent overcharging. Be sure to use an original JVC battery, as there is also a sensor in the battery to prevent overcharging and the inexpensive replacement batteries will not have the same sensor (some have NO sensor at all!)., In terms of keeping moisture out, avoid going from an extremely cold environment to a hot one, or vice versa as this can cause condensation to form in the camcorder. If you are taking the camcorder to a place where it might get wet, say the beach or out in the rain, place the camcorder in a ziploc bag to protect it. Be sure to rate this solution. Thanks!
Nov 08, 2008 | JVC GR-D270US Mini DV Digital Camcorder
Cameras Logo
53 people viewed this question
Top JVC Cameras Experts
Michael Galve
Michael Galve
Parshiv Luthra
Are you a JVC Camera Expert? Answer questions, earn points and help others
