I have a new motherboard Elitegroup H55H-M with a processor I5 760, it does not give of video, alone it issues bip of mistake. That can be?
  • 961 Answers
From the research I read(you're probably not going to like this), your board has an Intel H55 chipset that will produce video but only with the i5 or i7 "clarksdale" cpu's. Your average i5 or i7 will not support the video. there is no onboard grahics on your board, it's designed to work only with Intel 32nm Clarksdale. It sound like it would be an awesome combination.
Posted on Mar 23, 2011
On, but black sreen,also with extra video-cart,no bip,only fan processor isgoed running.
Greetings
I would be happy to help if you can give me some more info such as what MB you have and what trouble shooting you have done so far.
If you dont get a beep code then check the power connection to the MB to be sure its the correct power supply.
Chadman
Mar 17, 2015 | Computers & Internet
My Toshiba X200 doesn't show any image.I've bought a new motherboard, but still no image appears.The tech that told that the problem was with the motherboard (that was supposed to be burned).Now he tells...
enable what? BIPS? never heard of it in the last 10 years, are you sure you are dealing with a PC tech there?!
Have you tested that the RAM on the computer IS OK?
Have you tested that the Video card on the machine is OK?
has any real troubleshooting been done on the machine?
if he just told you the motherboard was burned without doing any other testing you are dealing with a fraud.
Nov 07, 2010 | Computers & Internet
Can intel dual core e5400 work on my motherboard?
Yes you can.
Your motherboard is LGA775 socket and supports the folowing processors:
Core2 Duo / Pentium Dual Core (yours) / Pentium D / Pentium 4 / Celeron 4xx series/ Celeron D.
Jan 28, 2010 | EliteGroup 945GZT-M (V1.0) Motherboard
Non si vede niente dal monitor
tre bip lunghi potrebbe essere un problema della tastiera.
Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco.
* Un bip = tutto funziona normalmente.
* Due bip = errore POST/CMOS.
* Un bip lungo ed uno breve = problema con la scheda madre.
* Un bip lungo e due brevi = problema video.
* Un bip lungo e tre brevi = problema video.
* Tre bip lunghi = errore tastiera.
* Lunghi bip ripetuti = errore di memoria.
* Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre.
* Continui alti e bassi bip = surriscaldamento CPU.
guarda anche questo sito
http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
Dec 31, 2008 | Intel D945GCCR Motherboard
VIDOE CARD PROB?
reseat the video card in the slot. then use the cmos reset jumper on the motherboard (when the power is off). if this doesn't fix the issue, then the card may not be compatible with the agp or pci-e slot that is on your motherboard. If this doesn't work (I am assuming your motherboard also has a default (onboard) vga out port - then go into the bios and set the primary display device to be the agp or pci-e slot.
Sep 26, 2008 | EliteGroup P4VMM2 Motherboard
Asrock K7S41GX "NEW" does not work :bip-bip-bip
3 beeps is a memory error. remove the memory and put it in the first slot.
also the memory replacement calls for ddr pc2700.
Robert
Sep 05, 2008 | Asrock K7S41GX Motherboard
Powers on but no video.
Your motherboards RAM is not working properly. First you try getting it out and installing again. If that not work you can change with other one.
Feb 09, 2008 | EliteGroup nForce3-A Motherboard
Will not boot up
Disconnect all the disks and CD, remove memory and everything else including all the added card (Video, network,etc..).
Power up with processor only and if you don't hear any beep you have a bad motherboard or processor.
If you have any beep power off and add the memory and try again. Keep adding one component at the time until you discover wich one is creating an issue.
PS Did you verify compatibility between motherboard and processor?
Oct 19, 2007 | EliteGroup P4VMM2 Motherboard
P4vmm2
your intel processor(weakened) may also be the culprit..try to swap other processor.
Sep 10, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
