Question about HP OfficeJet 6110 All-In-One InkJet Printer
Cutting off the left side of print, approx 2 or 3 characters???
  • lorealbuckha Jan 13, 2009
    I have 4x6 Invitation cards how do i change the margins to print them correctly
  • 1,601 Answers
Re set the margins
Posted on Aug 04, 2008
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Feb 13, 2011 | Seiko Office Equipment & Supplies
I have a Ricoh Aficio 1013 copier that has started to have an area of "ghost" printing in a narrow strip about 2" wide and 4" long on the lower left side of the copies that are being made. It appears to be...
Open the right door is there an image on the drum? (if not) It sounds though that your fuser has toner build up on it and is at end of life. These fusers are harder than most to rebuild so maybe a service call? -Carl
Jul 14, 2009 | Ricoh Office Equipment & Supplies
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Very faint printing in xerox 3117 laser printer
my ml 2010 never has printed as dark in the centre of the page even when the toner is full?
Sep 02, 2008 | Samsung ML 2010 Laser Printer
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Missing left edge
Sounds like you should first try the toner cartridge. Make sure you shake it and reseat it in the unit. Print a report. Data Reg., Report
Let me know if problem persists.
Jun 17, 2008 | Canon FAXPHONE L80 Laser
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
Missing left edge
try to change the settings of the printer. maybe your document is on portrate position and your margins.
Jan 31, 2008 | Samsung CLP 300 Laser Printer
IBM 6400 model i10 print problem
It's likely a "hammer" is defective. This can be caused by
a build up of ink under the ribbon shield and/or around the hammer "fret" itself or the fret is physically broken. Remember
that this is a "shuttle" printer and each fret covers anywhere from
one to three characters depending on model. Some cover fractions of characters as well. The problem will appear as either
data missing on the left or right margin or a blank column of missing data going down the page.
A technician is required to solve all of these problems as the
shuttle assembly must be removed.
Jul 27, 2007 | IBM 6400 Model i10 Matrix Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
166 people viewed this question
Ben Johnson
