Question about Fusion EN-AT1100 300W Bass Reflex Tube with 25 cm Subwoofer Car Speaker
Hi, i have a fusion EN-AT110 but i need to connect it outside my car, i need the name of the 12v power connector and how kind of power supply can i use to..thanks!
3 Suggested Answers
jpenn1192
  • 58 Answers
SOURCE: how do i wire up fssion en at110 to stereo with NO rca outs
WHAT U WANT TO DO IS GO TO A LIKE BESTBUY OR CIRCUIT CITY, AND ASK THEM FORM A RCA CONVERTER, THEM SHOULD HAVE WHAT YOUR LOOKING FOR, THEY CAN ALSO RUN ANYWHERE FROM $10-20.
Posted on Oct 26, 2008
SOURCE: Have no wires for a Fusion EN-AT110 Basstube!!!
The best place is to go to any store like halfords or maplin, or a lot cheaper if you wanna wait is ebay, many fusion amps/ active subs need special wiring !!!£80 from them direct only way, or you can go to maplin and get this product: A21GF (power supply extender 24pin) then cut off the three columns you need and the top and bottom of each are the respective 12v positive input remote and earth, cut the wires off half way and twist the top and bottom together, then add the twisted wires to your normal sub cables. make sure you use insulation tape around the naked wires for quality and stop it short curciting
Posted on Jun 14, 2010
This is my first build and all the connections are a bit confussing need picts of how to install cables to hardware
The following picture will definitely help you to install new power supply.
The 4 pin CPU power connector is using in most of the desktop motherboard. If your motherboard is gaming type or workstation board you need to connect 8pin CPU power connector. Molex connectors are using to power up DVD Drives and HDDs. In New model power supply instead of molex connector SATA Power connectors are coming.
Feb 12, 2011 | Thermaltake Toughpower XT TPX675M 675W ATX...
Hi, Which wire is +12v on 325W Compaq psu # 48002001? Kind regards
On the 4 wire connectors, the yellow wire is +12v, the red wire is +5v and the black wire is neg
Nov 19, 2010 | Compaq Computers & Internet
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Sep 12, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Dec 09, 2008 | Fusion FEW12PK Car Subwoofer
How do i wire up fssion en at110 to stereo with NO rca outs
Oct 26, 2008 | Fusion FEW12PK Car Subwoofer
Installation of foxconn 45cmx
Hi aligmatos, it is suggested that you use a 24-pin main power connector if you are going to fill up the motherboard & use a PCI-Express graphics card & Dual-Core Pentium CPU. The power supply should not be less than a 450W for this board, 550W would be better. You can use a 20-pin main connector but its not suggested. Make sure you connect the 4-pin 12V power connector. Your motherboard should still function with a 20-pin main power connector. Again I would not suggest it.
Main web site for Foxconn 45CM-S
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000328
Search preformed for Recommended power wattage for foxconn 45CM-S motherboard.
http://www.google.com/search?hl=en&q=Recommended+power+wattage+for+foxconn+45CM-S+motherboard&btnG=Search
Good luck aligmatos!
Mike
Aug 26, 2008 | Foxconn 45CMX socket LGA775 motherboard...
Piggy back power splitter
You can connect the splitter to any of the 4 connectors that power IDEs(Hard Disk, DVD ROM, CDROM etc.,). The splitter's sole purpose is to split one 12v supply into two 12V power supplies so that we can connect two devices instead of one. You can disconnect the power from DVD connect the splitter to it and then use one of the two 12v supplies from the splitter to connect to the DVD drive and the other to the HDD fan.
Jul 13, 2008 | Dell XPS 200 PC Desktop
Fusion EN-AT1100 300W Bass Reflex Tube with 25 cm Subwoofer Car Speaker Logo
275 people viewed this question
Top Fusion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
