The plastic paper cutter part broke on my calculator. Where can I purchase a replacement part?
2 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: THE TWO BLACK PLASTIC PAPER TRAYS TABS BROKE OFF.
. Check your Yellow Pages for a local Panasonic Office Equip. Dealer
Posted on Jun 09, 2010
My Shredder W11C stopped working suddenly both forward and backwar. The power source is O K.
if you can hear the motor working but the paper won't pull in and shred then you broke a tooth on the plastic gear. This happens when you try to shred too much at one time. It happened to me but I couldn't find a plastic gear or the company to replace the gear. I liked the machine so I made my own tooth with DEVCON home plastic welder. With a little ingenuity and some tools you could try to fix it. Or like someone said buy a new shredder
May 07, 2014 | Fellowes Office Equipment & Supplies
Royal adding machine 770 HD EZVue paper cutter
Here is a link to find the authorized service centers - contact the one closest to you:
http://www.royalsupplies.com/service-centers.html
Apr 09, 2014 | Royal Genuine Used 770hd Printing...
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
Cutter plastic drive block doesnt hold cutter pin
It sounds like the drive unit is the problem. This part can be purchased from shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
May 29, 2010 | Braun 360° Complete Electric Shaver
Plastic separator missing
It is a tedicous process but it can be done. Disassemble the unit (remove the gear cover). remove the cutters and use an end plastic and place it where it is most needed, usually somewhere in the center of the cutters. Make sure the cutters are oriented in the same direction so as not to jam the paper. Reassemble in reverse order. Make a diagram of the preassembly and use it to reassemble the unit. Take your time. Perhaps you could request a replacement plastic. I just used a plastic washer on the ends. I do remove shredded paper once in a while but that is just preventive maintainance. Hope this helps.
Dec 12, 2009 | Royal 10X Shredder
Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Aug 02, 2009 | Royal VF1012mx Shredder
Where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Mar 22, 2009 | Tech Solution TS-4500 Shredder
26 people viewed this question
k24674
jasbo
jasbo
