Question about Lexmark X5470 All-In-One InkJet Printer
Paper will not feed into printer, appears to be an alingment issue
    Genius:
  • 1,087 Answers
This article in the Lexmark website on Paper Feed Rollers Are Rolling But the Paper Is Not Feeding might help resolve the problem.
Posted on Mar 24, 2011
Epson u220b printer will feed paper but will not print
may you put the paper in wrong order just turn the paper up side down and then check if ok nothing to do if not u have problem with thermal head or head alingment
Jul 14, 2014 | Epson TM-U220 Matrix Printer
My Brother MFC8220 Keeps jamming the paper as it starts to enter the drum, is this a feed issue? or a Drum Issue? It appears to feed from the tray correctly, but then starts jamming as it enters the drum.
Using a cloth damp with water clean the feed roller. You will see it when you pull out the paper tray. If it starts feeding good it was a feeding prob.. If it keeps doing it look at the leading edge of the jammed paper for any signs of dings or bends. if you find any paper damage look in that area for what is causing the damage. Thank you, Steven 805-520-3003
Jul 26, 2010 | Brother MFC 8220 All-In-One Laser Printer
Paper fails to feed - small nicks appear in front edge which causes feed to not pick up sheet. Looks like feed mechanism causes nick. does not fail all the time. If I smooth it out or put paper in end for...
hi ..
do one thing unplug the power cable from the back of the printer..tap the on button fro 10 times..replug that..if issue is still not resolved then try to open the adf cover you will find small black rollers..clean that..
open the rear door you will find the same rollerrs there too..clean them..restrat the printer..issue will be resolved.
Jan 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
Canon Stylus C64 paper jam
try this link below. Although the printer is lexmark but it can used the idea to solve the problem regarding paper jam issue.
http://www.lexmark.com/publications/pdfs/lexmarkt522/eng/paprjams.pdf
Thanks
Jul 31, 2009 | Epson Stylus C64 InkJet Printer
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
I moved my computer and lexmark3470 to another room. suddenly i hook it back up [ports work fine} the three buttons on the left won't move up and down, and the printer keeps saying theres a computer jam...
If it shows false paper jam error try these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
I have just purchased ink cartridge 830 black for canon ip 1800 but the lights are blinking orange please tell me why this is happening
I received this response from canon.com. Hope it helps you.
If the paper feed rollers become dirty, they may not be able to properly
feed paper due to the feed roller's slippage. If paper does not feed
correctly, perform the following to clean the paper feed rollers:
1. Open the Printer properties.
For Windows Vista
a. Click / Select 'Start' from the bottom left of the Windows screen,
'Control Panel', 'Hardware and Sound', and then click on 'Printers'.
Note: If you are in 'Classic' view, Click 'Printers' directly from the
'Control Panel'.
b. Click your right mouse button on the listing for your printer, and
then select 'Preferences' from the menu that appears.
For Windows XP Home Edition
'Control Panel,' 'Printers and Other Hardware,' and 'Printers and
Faxes.'
For Windows XP Professional Edition
a. Click 'Start' from the bottom left of the Windows screen, and
'Printers and Faxes.'
For Windows 2000
and 'Settings,' then 'Printers.'
then select 'Properties' from the menu that appears.
2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
3. Remove all sheets of paper from the auto sheet feeder.
4. Confirm the following message, and click 'OK'.
Note: Clicking 'OK' will activate the paper feed rollers 30 times. This
activation will take about 90 seconds. Do not perform other operations
until this operation has finished.
5. Confirm the following message, and click 'OK'.
6. After the continuous paper feeding operations in step 5 have
finished, load three sheets of plain paper and click 'OK'.
7. Confirm the following message, and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
8. Click 'OK'.
Roller Cleaning is completed.
If the issue continues to persist, try fanning the paper before
reseating in the automatic sheet feeder.
Follow these steps to fan the paper in the Auto Sheet Feeder(ASF):
1. Remove all documents from the ASF.
2. Check for any obstructions.
3. Fan out the sheets of paper so that they do not stick together.
4. Align the edges of the paper.
5. Insert the document stack, face up, into the ASF until you hear a
beep.
6. Adjust the document guides to the width of the document.
If fanning the paper does not help resolve the issue then the iP1800
printer will require service.
special toll-free number for email customers with
unresolved issues and speak to a technician* by dialing 1-866-261-9362,
Monday - Friday 10:00 a.m. - 10:00 p.m.
Dec 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer
What kind of back door do you have on your machine. Does it have a knob that you twist to get it off or does it have pieces on the left and right you have to pinch to get it off. Reason for asking....
There were two versions of this machine put out that had two different service stations and paper feed mechanisms. One version had a motor for the paper feed mechanism and a motor for the service station. The other version just had a motor for the paper feed mechanism and service station movement was tied in to this motor This was done with an altered gear mechanism in the service station. This gear mechanism was cheap and it broke easily. When it breaks you get a knocking/grinding noise and no paper feed or service station movement. It can't be fixed.
THIS PROBLEM IS IN THE MACHINES THAT HAVE THE PINCH OFF BACK DOOR!!!
Hope this helps.
Inkworks
866-381-0541
Oct 13, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Printer
I have seen your issue on the paper feed for your printer. Well, I am thumu from india-Hyderabad. I would like provide my solutions on the issue.
This issue could happen due to the following below causes:
1. If you are not using the recommended Paper type for your Printer
2. If you feeding the Paper incorrect.
3. if paper type selected in the Printer Properties and the paper type that are trying to feed are mismatched.
4. If there is an issue with Paper Feed Rollers of your Printer. Or some times, the issue could also happen if there is some dust on the paper feed rollers.
5. If there is an issue with Printer software might have got corrupted.
Try below solutions :
1. Check whether the issue happens with all applications or not.
 If it happens with all applications, then we need to troubleshoot further or if it happens with Particular application like MS-word, then we need to check the Print settings.
2. Make sure that you are using Correct and recommended Paper type for Printing and same paper type is selected in the Printer Properties.
3. If the issue still happens, then please disconnect the Printer from Wall outlet and from Computer, try to clean the Printer paper feed rollers . Please look in to Manual or Instruction set that is given with Printer to clean Paper feed rollers.
If the issue still happens, then I suggest you to opt and go for online Chat Support  for your Printer. They can help you with much more information.
For your convienience, I would like to provide you web link for Online Chat Support for Lexmark Printers.
http://support.lexmark.com/cgi-perl/support.cgi?ccs=229:1:0:520:0:0&
Once if you open the web page please click on the chat Support . This will get you to live Chat Support agent.
I hope that this should resolve the issue for you.
You can mail me at thumuvikram@rediffmail.com if you need any further assistance on any issue. I'll be glad to help you.
Oct 02, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
90 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
