Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
I have a frigidaire side by side #FSC23LR5JM2 that is not keeping cool enough. Age is aprox 1.5 yrs. Noticed the problem over a couple of days. Turned the temp cooler by 2 numbers in the frig and freezer, but seems to be running about 50 degrees. Doesn't appear to be blocked coil.What else should I check or procedures to perform?
    President:
  • 2,468 Answers
If the freezers staying cold but not the refrige section,then its the damper vent door between the freezer and refrige section thats either frozen shut or the damper door motor is bad or without power,if nothings cold as in freezer and refrigerator sections,then its the ptc overload & relay on the compressor thats bad,unplug the ptc overload & relay off the side of the compressor and obtain an exact replacement and plug in the new replacement and it will again cool
Posted on Mar 23, 2011
Why is my refrigerator not cooling properly?
Low on refrigerant gas due to a leak
Broken thermostat
Failing Compressor
Iced up evaporator
Feb 03, 2016 | Frigidaire Refrigerators
Why isnt Fridge cooling
There are numerous reasons for a refrigerator to discharge only cool air; weak compressor, low refrigerant, etc.
However, there are two very common reasons for refrigerators the age of yours to under cool. 1. Dirty condenser coils. Check the condenser and ensure that it is clean. This should improve performance. If that does not solve your problem then 2. The evaporator is freezing up. This can be caused by a faulty defrost timer, a failed defrost element, or a faulty defrost thermostat.
Aug 24, 2014 | Frigidaire Kennmore Water Filter 2 Pack
Fridge isnt cooling
However, there are two very common reasons for refrigerators the age of yours to under cool. 1. Dirty condenser coils. Check the condenser and ensure that it is clean. This should improve performance. If that does not solve your problem then 2. Evaporator is freezing up. This can be caused by a faulty defrost timer, a failed defrost element, or a faulty defrost thermostat.
I have a Frigidaire FFU17F5HWD upright. I noticed
Reset the circuit breaker. It too maybe a GFI circuit.
Oct 11, 2013 | Frigidaire FFU17F5HW
Power on but not cooling
mostly either compressor or relay is bad. replace relay and see if it works, since that is cheaper part..
Jan 03, 2010 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
My 18.2 cuft hotpoint refrigerator 2 years coils overheat
the drain on the unit is probebly clogged up or frozen . take and manually defrost the unit and check the drain line to see if i0ts clogged up.
Feb 01, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Dec 09, 2007 | Frigidaire Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
202 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
