Question about Panasonic KX-T7630 Corded Phone
I have programmed the one-touch dialling but this has caused the little red light on the outside line button not to display with incoming or outgoing calls. Im at reception and this function was great but since reprogrammimg the keys it has gone. email address susan.shaw@det.wa.edu.au
  • Panasonic Master
  • 2,460 Answers
No, post here, read here, no email to you.
Press PROGRAM and the button you unprogrammed. If it's a CO line, dial 0 + 001,002,003 or whatever and STORE. That puts the lines back under the buttons.
Carl
Posted on Mar 23, 2011
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
II can make outgoing calls and my broadband is working well but it is not accepting incoming calls
There is either a fault on your line (get in touch with your supplier via email) or your service has been restricted by your provider, again email them.
Dec 11, 2014 | Lands Phones
When following the instructions for progamming one touch dialling, the result end with a message saying 'not valid' when trying to use the number - can anyone help?
Press Program Press the button to store Press 2 then your outside line access code (usually 9) Then dial in the number to dial Press Store
Oct 03, 2013 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    I set the One-Touch Dialling to CO. Please teach me how to cancel this setting.
    The only buttons you can set to CO are the left side buttons with lights, so assuming that, press PROGRAM the button dial 2 STORE. That clears the button. Now, just in case you lost the sequence of buttons for outside lines, from the bottom press the left side buttons and read them. If they're not in 1234 sequence, dial 0x STORE to restore the CO line that belongs there.
    Carl
    Jul 01, 2011 | Panasonic KX-T7730 Corded Phone
    How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
    The answer to the Caller ID question:
    Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
    The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
    Ther answer to the incoming call line ringing question:
    Again, depends on the system. For the Partner ACS:
    1) Press FEATURE 00 at extension 10 or 11.
    2) Enter the number of the extension to be programmed for Line Ringing.
    The green lights next to the line or pool buttons show the current Line Ringing settings for all
    lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
    light next to that button is off.) The following ringing options can be shown by the green light
    next to the line or pool button:
    ? Immediate Ring - on steady
    ? Delayed Ring - flashes slowly
    ? No Ring - flutters quickly
    3) Press the line or pool button until the button light shows the correct setting (the setting for the
    currently selected line or pool also appears on the display).
    4) Continue programming, or exit programming mode.
    Line selection:
    For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
    1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
    2) Enter the number of the extension to be programmed for Automatic Line Selection.
    3) Press **.
    4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
    Line Selection
    depend upon the type of extension:
    ? Key Extension: Outside system lines, Left Intercom (the factory setting)
    ? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
    setting), Pools 881-883, individual lines
    For each button pressed, a display similar to the following appears:
    5) To exit Automatic Line Selection, press **.
    6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
    Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
    Jan 06, 2011 | Lucent 18D Corded Phone
    Can't make outgoing calls
    Hi, have you checked from your service provider that you have an outgoing service? Any number of problems could cause you to lose outgoing dialling, and some of these causes are outside of your control. In my opinion, I would first try a different phone; plug that into your line and see wether you have the same problem. If you do, I would first check your immediate surroundings to make sure that nobody has tampered with your line. Secondly, get your Telco to do a line test; they may charge a smal fee for this, but this depends on region and of course your provider. Might also be advantage too check any other connections and microfilters if you have those. If you have a broadband line, then consider unplugging your computer and router from the phone line and do the test by the main socket with just one phone. More sockets? check these one by one. This is the best way, and the most secure, may save you a lot of time and aggro in the future, and lets face it. If it is the handset, they are cheap enough to replace, but test your line first because this is more expensive and time consuming.
    I hope this is the fixya for you, and best wishes in resolving this issue.
    yours sincerely
    oz
    Feb 23, 2010 | Uniden Cordless Phone
    HOW TO PROGRAM ONE TOUCH DIALLING FOR KX-T7730 WITH CO BUTTONS ONLY ON THE RIGHT?
    So that we're on the same page, a 7730 has PF bottons on the right and "CO" buttons on the left. If you have a different phone, like a TA-308xx or a Euro phone that isn't offered in the U.S., then it may only have a single row of buttons.
    Programming is the same. If the button is a CO button (with a light), then your one touch requres a "2" in front of it to speed dial a nunber and a "9" or outside line access code to dial an outside number. So, to call 212-555-1212 you press PROGRAM the CO button, 292125551212 STORE. An inside number is stored under the CO button with a "1" plus the extension number.
    A PF button already has the assumed "2", so you would just dial 92125551212 in the example above.
    Carl
    Dec 13, 2009 | Panasonic KX-T7730 Corded Phone
    How do you save numbers for one touch dialling?
    Press PROG the button and dial 2 + 9 + the number and STORE.
    If your outside line access code is something different, insert it instead of "9".
    carl
    May 20, 2009 | Panasonic KX-T7630 Corded Phone
    Tel KX-T7330
    The system that the 7330 is connected to controls how you program it and how it behaves.
    In the U.S. and for only a short time, the 7330 phones were connected to a TA-624. In fact, those phones were called "Euro Style" so you may be in the U.K.
    I don't recall if they have a PROGRAM switch in the back or a PROGRAM button on the face, but they are programmed with PROGRAM press the button you want to program and read the display.
    In Panasonic, all C.O. lines are assigned with 0 plus the CO number 1-6 in a 624's case and STORE. So you can reprogram the buttons in top to bottom or bottom to top order with 01 STORE 02 STORE etc. In passing, all extensions are programmed with 1 plus the 3 digit extension number as in 1101, 1102,1103 etc.
    If the puttons are physically sticky, you can use alcohol and clean them, or just reassign them.
    I hope this helps :-)
    Carl
    Mar 15, 2009 | Lands Phones
    Panasonic KX-T7630 Corded Phone Logo
    71 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
