Question about Lands Phones
BT XD5500 manual
I have lost my manual and cannot register the phone to the base unit
BT Freelance XD 5500
Resetting the base & handset/s on a BT Freelance XD5500:
Hold the Find button on the base unit until you get a double beep then
tap the Find button 7 times.
On the handset:
remove a battery
hold the menu key and refit the battery
screen says SW VERSION
press up arrow key until screen shows REGISTER CLEAR
press menu
press menu again and wait for OK to appear
remove a battery and refit
Registering the XD5500 handset.
Then register the handset to the base as follows:
Hold Find button on base unit until you get two beeps
On handset:
Press menu
Scroll to register
Press menu
Scroll to Register Base
Press menu
Press 1
Wait
When it says PIN ? Enter 0 0 0 0 (four zeros) and press menu.
Note:
If you have more than one handset then repeat registering the handset to the base for each subsequent handset/phone.
If this procedure fails to solve the issue, then you have a unit with a
fault and if it is less than a year since purchase the retailer should
change it for you.
Posted on Nov 14, 2009
  • Kevan Craft Nov 14, 2009
    You can buy a replacement BT Freelance XD5500 base from sellers on eBay for £3.99 for the base and £3.99 postage & packing..
    http://stores.shop.ebay.co.uk/AK-Product...
    Upon purchase you need to reset the base by following the instructions above...
Have acquired an additional handset with charger. The screen flahes a 'Please register' message. How do I do this?
Assuming you do not have 5 handsets already, make sure that the new handset is fully charged. Carry it over to the base and press Find on the base unit. (This sends out a signal to the handset.) On the handset, press Menu and use the Up arrow to go to the line marked Settings. Press Menu to access this sub-menu. The line H/Settings should be highlighted. If it isn't highlighted, use the Up/Down arrows to navigate to this line. Press Menu to access this menu. Use the Up/Down arrows to navigate to the line Register. Press Menu again. Use the Up/Down arrows to select the base to which you want the handset to be registered. Press Menu again to confirm that base registration. Enter the system PIN for this base; the initial PIN is mentioned in the manual on page 35 and on page 54. Wait for the handset to indicate that it has been registered; it will say Registering until the process is finished. If you take too long to do the steps at the handset, the signal will stop and you will need to start over.
If you already have 5 handsets, you will need to de-register one of them. If the registration process does not properly occur and the issue wasn't taking too long, either the base or the handset is not communicating properly. If other handsets work, I'd suspect that the new handset is faulty.
BT Systems has the manual on the Freestyle 750 product site: http://btbusiness.custhelp.com/app/answers/detail/a_id/12103/~/bt-freestyle-750-user-guide . The direct link to the manual is http://btbusiness.custhelp.com/ci/fattach/get/223683/1232386209/redirect/1/filename/BT_Freestyle_750_user_guide.pdf . The procedure to register the handset is on pages 53-54 of the manual.
I hope this helps.
Nov 02, 2015 | BT Freestyle 750 Digital Cordless Handsets
How do I rescue my BT Freestyle 750 from being stuck "Searching" and remedies that are "Not Possible"?
Have you tried removing the batteries and letting the internal power decay for an hour or so - in other words try to get them to forget what they were. Then replace batteries and try again. I guess you've consulted the user manual, is there a reset button hole anywhere on the base unit? The sort you stick a pin into.
May 19, 2015 | BT FREESTYLE 750 TWIN DIG CORDLESS PHONE
How do i reset the BT XD 1500 as had to replace hanset and can not get to work with the base?
uk-surplus.com/manuals/freestyle2200.pdf - United Kingdom
user guide above. please download
Please follow the instructions in the manual and no doubt you will get it all working again.
You most likely simply need to reset and re-register it with the Base.
Aug 12, 2010 | British Telecom Freestyle 2200 Trio...
Have just bought a second hand BT mango telephone with 2 extra handsets.There doesn't appear to be anywhere to connect the phone wire to handsets 2 and 3. Only a socket for the power supply. Is this right?
There isnt a socket to connect the additional handsets because it is not needed. The handsets all use a single line by connecting to the base unit. You need to make sure the additional handsets are registered to the base unit.
For how to do this and anything else look in the manual which can be downloaded for free at http://phone.manualsonline.com/manuals/mfg/british_communications_bt/bt_mango_1_2.html
Aug 14, 2009 | Uniden Cordless Phone
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
BT2200 how do i pair a phone with the base station? I lost the manual that says how to do this
Here are the instructions for registering a new handset for the BT Freestyle 2200.
Nov 08, 2008 | British Telecom Freestyle 2200 Trio...
BT Studio 1000 4 handsets
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
Bt quratet 1100 no dial tone
Sounds like the phones have not been registered to the base unit. Look in the manual for directions on how to get the phones and the base unit to talk to each other. Sorry, I don't have any details on theis model to look up the instructions.
Jul 23, 2007 | GE 25831GE3 Cordless Phone
Lands Phones Logo
923 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
