Question about Kenmore Ovens
Kenmore 790.4658 slide in electric range. Oven door locks and will not unlock (followed the reset directions in the manual). I get an F 90 error code. Any suggestions?
  • 1,998 Answers
This error code refers to a problem with the the eoc or electronic control if you are unable to clear the code you will have to replace the eoc
Manufacturer part number 316418207 is RepairClinic item number 1062435
you can also open the door by taking off the back panel and spining the motor or disconecting the control arm from the the motor might be easier to just spin the motor though If you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks for using Fixya
Rick
Posted on Mar 23, 2011
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
After cleaning the outside surfaces of the stove, the oven door is locked and does not unlock if we push the stop button. Display reads LOC. No self cleaning cycle was initiated. The stove is a Kenmore...
What about child lock? Read user manual or try holding button for 10 seconds, might be two at once.
(I bought a $200 control board and travelled 150 kilometers for that one....)
Oct 15, 2013 | Kenmore 49043 Electric Single Oven
F-90 error - self-cleaning ovn door will not lck and now light flashing and cannot use oven
Good Morning Nancy, I am happy to assist you!
If you are receiving error code F90, your maximum oven door unlock time has exceeded. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either flipping off the breaker or unplugging it for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further since the unit may possibly have a faulty EOC (electronic oven control), lock motor assembly, door light switch or door latch assembly.
Best regards!
Oct 15, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
How do i unlock after self cleaning my kenmore elite electric slide in 30"
Hello,Give it time for the oven to cool if it has just completed the clean cycle. The door is not to unlock if the oven is still too hot. If the oven is cool and the door will not unlock,program and start another clean cycle and after about two minutes press cancel/clear/stop and wait for another minutes to see if the door will unlock.If the door doesn't unlock i recommend calling a service technician to diagnose and repair your range.
Thanks
May 29, 2010 | Kenmore Ovens
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Kenmore Electric Range Slide in....beeping while not in use
Hard wiring is O.K. and really better because you don't have to fool with the plug and the loss of or poor connection there. You can just turn the power off at the breaker. Without knowing what the F9 error code is, you may have a problem with the board inside the control panel. To get the door open, try to push and hold door closed at the same time. This may loosen the tension on the closer and allow it to open. Pull the lever to open it. If not, try to moderately tap on the door where it latches and it may open then. Next, slide a thin screwdriver into the latch and free it up there. Once the door opens, I believe your oven will work. The oven believes it is in the self clean mode. When you get the door open, turn on the oven with the door open and it should heat. If it does not, check the wiring in the back and you may find that one of the wires has burned off the control switch for the oven. I know this sounds like a lot, but it should save you a tech call and a couple of hundred dollars. Hope this helps.
Jan 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Stove won't unlock
some of the kenmores have the door lock motors in the back behind the large panel slide out an remove panel an pull or push the rod to unlock door if motor is bad for a temp fix just remove rod
Aug 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore locked
The www.managemyhome.com website has some troubleshooting options when the door wont unlock. Good luck. Also you can download the whole manual online it you have your model number. Mine was inside the drawer under the oven.
Apr 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
247 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
