Question about Jabsco 3 Flexmount Blower 105 CFM 12v 360 adjustable Outlet High Volume Air Flow Low Current (Jabsco)
We have 2 Jabsco Flexmount continuous duty 4" blowers in our engine room on our yacht. These still work after 8 years but getting quite noisey. Your suggestions on what we can do to improve the running noise and make them quieter please would be most helpful
    Sergeant:
  • 298 Answers
The first step would be to identify whether it is the blowers themselves that have become noisy - could be due to a build up of dirt, particularly on the fan blades affecting their balance, or could be that the motor bearings are getting a bit worn.
An alternative source of the noise might be that the mountings or any connecting hoses have become harder over time and are therefore transmitting more vibrations to the structure of the boat.
Posted on Mar 23, 2011
I replaced the jabsco accumulator tank on my yacht and the water pressure is fine except when the hot water faucet is turned on. how do I tune the pressure to be constant ?
check the on off pressure switch for the pump
regardless of hot or cold water requirement the accumulator should be connected so that either hot or cold gets the same water pressure
Apr 23, 2017 | Plumbing
Is it a good investment to buy a yacht?
Investment to buy Yacht is a very outdated it is very costly and requires maintenance and security. Value of yacht keeps decreasing. It's a black hole which keeps taking money until you get poor and does not give any return. Yacht investment is very risky. You can't sell it if you want your money back!
You should better invest in healthcare startups which are the future. They will give you faster and sure returns in around 4 to 10 years. Their is much less risk in investing in companies which have patents and clinical studies. Contact Kavas Yachting Charters in Greece with details like how much money you have so that you i can recommend you investment opportunities which are profitable to invest with good returns.
Nov 30, 2015 | Boating
How much does it cost to rent a yacht in Greece?
Really a bunch of factors that contribute and decide the cost of a yacht's rental price. Also the cost of yachts influencing by the following factors like size of yacht, location, season and time duration. Important factor is the size of the yacht which determine the actual price of a Yacht. But if you are looking for affordable cost yacht for rent then the best option is Kavas Yachting in Athens, is one of the longest-established sailing holiday businesses in Greece with over 25 years of experience in our industry. Provide you a wide range of option as per your need. For further info explore Kavas Yachting
Do I need a special license to sail a Yacht?
You do not need a license to sail your Yacht. However, if it is not yours and you are renting it, you may need a sailing license or some sort of certificate that proofs that you are capable of sailing the boat.
Also keep in mind that this may differ from country to country so you may want to double check.
Jan 17, 2013 | Boating
2006 F250 the blower for the a/c and heat quit working. I checked fuses and found none blown could it be a relay or something else?
the most common problem with blower motors if not the fuse is the blower resistor that controls all the blower speeds.the resistor is located in the heater air box near the blower motor and there is usually about 4 wires in the plug.
Mar 15, 2011 | 2006 Ford F-250 Super Duty
I have a 8 hp snow blower,I would like to know what the oil capacity of engine and what type of motor oil i should use.What weight oil?and can you use regular sae motor oil automotive type non detergent ?
Your question as I received it did not specify the engine make, but most 8 hp Techumseh, B&S and Powermore engines take 22 to 32 oz of oil. Buy a quart, put two-thirds of the quart in the engine and check the level with the dipstick or fill hole. Add more if needed to come up to the "full" mark.
All the manufactures and Craftsman recommends 5W30 for 4 cycle winter use.
You can use regular sae oil, but I prefer to use Mobil ONE or a heavy duty oil because air cooled engines run hotter than car engines. Look for a SC/SD or greater rating on the bottle.
Change your oil once a year.
Feel free to as any other questions about your snow blower. Don't forget to rate this answer!
Jan 12, 2011 | Garden
I have a Quadra fire 1200 pellet stove insert. The convection blower does not stay on continuously. 2 min on 2 min off
It may be working properly. If it seems that it's a little cool in the room and the blower is cycling like you say then the stove may be getting chilled. If this is the case then the low-temp switch is cutting the blower off.
If the room is quite hot there may be a problem with the blower. Check to see if it has a bunch of dust in it making it run hot and tripping the internal thermostat.
Please respond with the 'comment' button, down below the ads. I'm considering a pellet stove and I'd like to hear anything you have to say about yours.
lp
Jan 11, 2011 | Napoleon Auburn Pellet Stove Heater
Brake lights on 2003 super duty quit working
Please see my tip at http://www.fixya.com/cars/r6053280-lights_out_lights_not_out_bulbs_ok . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
Oct 03, 2010 | 2002 Ford F250 Super Duty SuperCab
2005 F350 Blower either works when truck is started or it don't. Does not ever come on, if it didn't at start up. Also, if it works when started, it never quits working. It just started this about 4 days...
dont quote me on this because i have never a this model truck here in spain ,but if i am not mistaken their is electronic panel behind the dash in the radio area and this panel controls the heater controls and radio security ,think this might be your problem enquire at dealer
Jan 07, 2010 | 2005 Ford F 350 Super Duty
I have a jabsco 8'' searchlight, it slews however the light went out, is this replaceable or is a whole new unit needed.
Seems like it MUST be replaceable. Look it up on the net. http://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENUS331&=&q=jabsco+searchlight+parts&aq=1&oq=jabsco+searchlight
Jun 16, 2009 | Boating
Jabsco 3 Flexmount Blower 105 CFM 12v 360 adjustable Outlet High Volume Air Flow Low Current (Jabsco) Logo
119 people viewed this question
Top Jabsco Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Jabsco Boating Expert? Answer questions, earn points and help others
