Question about Raypak SpaPak Spa & Hot Tub Electric Heate...
I've had my Raypak SpaPak (smaller model) for about 2 years. It seems like it doesn't seem to heat the water as hot as it used to - I need to turn the dial to a higher setting to bring the pool up to temperature (I keep it around 85 degrees). Do I need to clean anything or have elements replaced? My electric bills have been considerably higher and I wonder if it's because the heater may not be heating efficiently.
  • 310 Answers
If you do not keep close watch on your water chemistry, depending on your location , you could have a large calcium build-up or salt build up on your electric heating element. Also, these models are meant for spas, and depending on the weather in your location, the heater might have trouble keeping up.
Posted on Mar 23, 2011
No Heat on My Raypak 1102-2 Spa Pak
check pressure switch if not enough pressure not enough voltage to complete circuit make sure filters are clean
Dec 14, 2013 | Raypak Spapak Electric Spa Heater -...
My Raypak spapak 11kw 1102 has deveolped a leak at the base of the heater tank. Small pin hole leaks in the copper tank. This is the second one to leak (replaced one two years ago) at the same place? Why...
make sure pool chemistry is in balance too low of PH and too low alkalinity will eat through the heat exchange copper PH should be between 7.2 and 7.8 alkalinity should be between 80 and 120
Oct 01, 2012 | Raypak Spapak Electric Spa Heater -...
Just replaced the heating element on my Raypak 1102-2 Turned the unit on & the on light didn't come on. Did i replace the element for nothing? What could the problem be THANK YOU
Check your high limit. This is the reset switch behind the rubber button on the face of the heater. It probally tripped during the process and didn't get reset.
May 12, 2010 | Raypak Spapak Electric Spa Heater -...
Heater runs 5-10 minutes then blows the breaker
After raising the water level in the pool I had no results. I bypassed the pressure switch and nothing happened so it was not the switch. Then I turned on the current for a few minutes, this moved something as it works now. So I conclude that the problem came from letting my water level get a little low.
Mar 26, 2009 | Raypak Spapak Electric Spa Heater - Els552...
Raypak SpaPak Spa & Hot Tub Electric  Heate... Logo
172 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
