Question about Canon iP100 Portable Printer
Vertical white lines appear in my printouts. - Canon iP100 Portable Printer
    President:
  • 739 Answers
Hi
white line or paper prints are enduring problems in the printer heads. software for cleaning the printer heads and see the results, if necessary, you must convert to the new printer heads
regards
Posted on Mar 23, 2011
Officejet pro x476dw vertical lines after print
Run the "clean inkjets" routine followed by test pages until printout appears correct. Maybe the print cartridges are defective.
Aug 06, 2014 | HP Officejet Pro X476dw Wireless...
Vertical black line at the bottom of my printout
open copier front cover and remove developer unit, after that remove the drum unit ,pullon green handles on each side, the drum unit has a green cleaning lever on it ,make sure it is all the way to right side,
arrows on lever and frame of drum should meet,if this is out of position a line will appear.
Mar 20, 2014 | Kyocera FS-1135MFP
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
Nov 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have vertical lines on my printouts
Brother MFC 7340 Vertical line appears on printout when document feeder us used.
Sep 03, 2010 | Office Equipment & Supplies
One day my tv started having white lines in various places, then one day the scrren went white but still has a small line across the top that works fine
The problem is "Vertical Over-drive" and the white lines are vertical retrace lines. What has happened is a component failure between the vertical oscillator and the vertical driver circuit. The component is usually a capacitor that is leaking and allowing voltages to appear where they shouldn't be.problem component is leaking and allowing DC voltages to appear where they don't belong. It's causing the vertical driver transistor to run "flat out" and will ultimately burn out the transistor from internally generated heat.
Hope this help....
Jun 18, 2010 | Televison & Video
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Unreadable printout
You have to set the printing properties to print not in draft mode... it should be in graphic mode... it prints slow but it surely gives you what you want.
Oct 25, 2007 | Epson LX-300 Matrix Printer
Canon iP100 Portable Printer  Logo
160 people viewed this question
old marine
old marine
