Question about Bosch Dishwashers
I am receiving an E25 error message on my Bosch Ecosense dishwasher SHE6AF02UC.
5 Suggested Answers
  • 12 Answers
SOURCE: I bought a Bosch Ecosense Dishwasher from Lowes in
press the delay button till it turns off or to 0 then try it.
Posted on Mar 03, 2010
Richie_asg1
  • 1036 Answers
SOURCE: latch is not working properly
It's possible the machine is slightly twisted.
Try re-levelling it to start.
You can usually tell when the door is not quite closed if it looks out-of-centre.
The next thing to check is lubrication of the catch. Try some WD-40 in the latch mechanism.
If still no better, then the latch may need adjusting by removing the front panel (unplug machine before doing this).
Grease the moving parts and adjust catch for easy closing.
Posted on May 02, 2010
  • 35 Answers
SOURCE: i have bosch she6af02uc,just installed,
CHECK WIRE OFF ON WATER VALVE OR FLOAT SWITCH THE DW IS NOT GETTING WATER. FILL BY HAND AND SEE IF IT RUNS
Posted on Jan 07, 2011
SOURCE: Siemens ecosense dishwasher error code
hello - what does error code 25 mean on the Siemens Ecosense dishwasher? Thank you
Posted on Feb 28, 2011
Error E:25 on bosch dishwasher smv53A00gb/24 what does this mean
E25
Drain pump blocked or pump cover missing
This can be caused by the above or by, as the fault code indicates, a blocked drain pump.
Dado
Feb 21, 2015 | Bosch Dishwashers
Bosch dishwasher model she6af02uc/03 odor
try running some bleach in the wash cycle
Aug 28, 2012 | Bosch Dishwashers
My bosch dishwasher she6af02uc is showing an E-24 error what is this
error code E24 = Drain hose blockage or pump impeller failure, suppose running it with filter unsecured would allow some goodies to get in there.
Changing the fine mesh filter should fix this.
Jun 29, 2012 | Bosch Dishwashers
What is E25 on my Bosch super silence dishwasher?
I quote same wrong from other user:
Question: Model dishwasher is Bosch Exxcell SMS50E02
It stopped before the end of a cycle with the error code E:25 and the "check water" light came on
I mopped out all the residual water out of the bottom and then ran a rinse cycle, which after several trials I got to work and then it stopped at the end again with the same error code and water in the bottom as before.
Answer:
I assume by in the bottom you mean inside the dishwasher and not in the base.As long as there is no debris in the sump area and the hoses are clear it appears you have a bad drain pump.
Hope helps.
Apr 03, 2011 | Dishwashers
The control panel on my dishwasher is showing a tap and E15
Mine's a bosch, same problem but started with E25 due to broken glass in the pump impeller, after struggling to remove it and then testing, it eventually moved to E15 as rightly so, no water was entering the machine due to the E25 code. The advice above is good, but take the device out first and tip the machine. This cured my faults without the need for a service call or spare parts.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
382 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
