Question about Sector 600 2653917025 Watch
Hello expert! My dial clip wouldnt stay shut and consequently the dial came off and was lost it must be spring loaded i was wondering if this was a manufacturers defect the clip and have other sector owner had this problem i am looking to find a replacement dial and possibly a spring sector 600 gmt24h thank you, Scout
Akribos xxiv AK736BK.. How do you resize the band? I got this for my boyfriend's bday gift and it just slides right off his hand. Help please.
Each link near the clip has a Spring- loaded PIN securing it to the other link, remove as many links you need and join the two open ends back together, a watch shop will do it too. $$
Feb 09, 2015 | Akribos Watches
How to remove stainless steel wrist band on a marc
You should find a couple of pins buried away at the watch side of the strap. These are spring loaded and hold the strap in place using tension.
Simply put the watch face down on something soft, the clips should be visible at the corners of the strap and take some needle nose pliers or small flat screwdriver and push inward from one of the outer edges. This will squash the spring and enable you to remove the strap.
Oct 15, 2014 | Watches
I purchased a S&W sd40 ve the clips rattle when loaded? not happy about it?
Common problem with these clips. I just bought a new SD40 yesterday and both clips rattle. Nothing you can really do. I read on a forum where a guy swapped the lower place and spring from a glock 23 clip and it fixed it.
Jan 09, 2013 | Smith & Wesson Watches
While replacing battery in my Casio 2688, I lost one of the three springs. What can I do?
yes you can , if you get a spare old watch or go to watch shop and get spring loaded bar for watch strap snap it open you can use the springs off then
Dec 28, 2012 | Watches
Ga100 spring replacement
l reckon you could substitute it for a spring from a used Bic lighter, remove the metal cover then prise open plastic and be careful to release the flint and there is your spring just cut it down to size. easy peasy...Glad l could help..
Oct 17, 2017 | Casio Watches
Hello I have two nixon men's wrist watches that
just bring your watch to Nixon watch experts. they have spare and tools to repair your watch.
Jul 14, 2011 | Watches
Battery won't clip in
There are tiny hooks. Get an eyeglass and you will find them. For easy fitting bend clip legs inwards a bit (do not brake). If hooks are not damaged clip should stay on.
Jul 28, 2009 | Garmin Forerunner 50
My problem is not mechanical. Rather, an issue of authenticity. I see a lot of information regarding replica LUMINOX watches. My question is: How can a potential buyer detect a "fake" from the real-deal?
Well I'm, not an expert of fake Luminox, only the real ones, but I will tell you that a 'real' Luminox will be heavy to the touch, good quality steel...another thing that is a must if it is real is the glass tubes on the hands and on the dial at the hour markers...they are very small glass tubes that are not 'charged' by putting in light, they stay lit regardless of any surrounding factors...most fake watches will have 'painted' on glow onto the dial and especially the hands...this model also has a screw-down crown and sapphire crystal...hope this has helped...good luck :)
Jun 07, 2009 | Luminox Marine 1590 Wrist Watch
Citizen watch bezel does not stay in place.
If you've been trying to snap on that bezel and it does not stay in place, you probably lost the bezel fixing spring.
Find your nearest watchmaker and ask to sort things out.
Dec 17, 2008 | Watches
Casio illuminator, w-94h
There is a tiny spring that must make contact with the back cover plate when you screw it back on. If the spring is missing, the piezoelectric buzzer will not work. The tiny spring is located toward the upper right in this photo of a Casio W-94H watch, directly underneath the "C" in CASIO that is etched in the metal. Note that the word CASIO is upside down in the picture, so if you can't see the picture for some reason, the hole for the tiny spring would be directly above the "C" in CASIO.
Nov 25, 2007 | Casio Sea Pathfinder SPS2011V Wrist Watch
Sector 600 2653917025 Watch Logo
60 people viewed this question
Top Sector Watches Experts
staicuma
Level 1 Expert
aravind shet
aravind shet
Are you a Sector Watch Expert? Answer questions, earn points and help others
