Question about Goodman Heating & Cooling
Defrost board for a modle cpke361b. I need to know what the part number is or where i can get one.
  • 96 Answers
Call any goodman dealer
Posted on Mar 24, 2011
I am wondering if a bad despenser contrl board could cause my ge side by side refrigirator frezzer modle # GSL25JFXB LB COULD CAUSE TO FREZZ BUT NOT COOL THE FRIG
No ... dispensor control has nothing to do with what you are describing...
TOTAL DEFROST circuit failure... MOST PROBABLE.
Note: appliancepartspros has 365 day return/guarantee...
You can order all your parts and return in-used or BROKEN parts...
Pull your defrost pan and check for ANY moisture...
(should get wet ABOUT twice each day...
(put typing paper in pan... you will see if it GOT WET).
No water = defrost failure...
- timer/control (good possibility)
- heater element (rare)
- defrost thermostat (most likely)
Check your model number and compare parts numbers. Ideal part number source is from you 'ORIGINAL OWNER'S DOCUMENTS".
SEARS (searspartsdirect.com) has a pretty decent technical library.. but their parts usually TOP the market...
You get the very same parts EVERYWHERE... so this is an excellent time to shop around (see below)...
Ice/frost has the flow of cool air blocked...
It will continue to get thicker until only the very bottom of your FREEZER will continue to work (very poorly).
Not a difficult fix... just make sure to take USEABLE PICTIRES before taking things apart...
(look at them... like you need them for re-assembly).
Good luck, hope this helps...
GE WR55X10942 Main Control Board AppliancePartsPros com
Oct 03, 2016 | GE Refrigerators
Defroster not working
The WR51X322 Defrost Heater Assembly
could be burned out in your model. Can you look inside the fresh food section and find the model number for me. The answer to the problem on your model depends on having the correct model number so I don't miss other parts that may cause a defrost failure. I know you said Monogram Side by Side but that does not tell me for sure what the Model Number on your refrigerator is. If your model is like the models in the GE Monogram Refrigerator Service Manual the I can have an idea of those parts. Those models have the defrost controls as part of their motherboard and that board does not fail at least in the defrost part of the board. defrost very often. You may need to also test or replace the WR50X10088 Defrost Thermostat I will be here should you have questions Thanks Sea Breeze
Apr 07, 2013 | GE Monogram Side by Side Refrigerator
My key board will not stay lite Modle Number G736
Does it go off on battery and AC power? Open power settings, change to High Performance, open Advanced Power settings, adjust settings.
Dec 17, 2012 | ASUS Computers & Internet
My modle number is aruf 036-00a-1 my serial number
MY MODLE NUMER IS CPLE42-1 SERIAL NUMBER IS 010940037
Aug 04, 2010 | Goodman CKL36AR36 Air Conditioner
What if both sides of the refrigerator is not getting cold?And the back of the freezer side has frost.
Defrost problem. Either the defrost thermostat, defrost heater or defrost control board needs replacement. The defrost heater has to have continuity. The defrost thermostat has to have about 0 Ohms while it's cold. If both test out ok - replace defrost control board.
Part locations: Defrost heater and thermostat: under your frosted cover; control board - left upper corner of fresh food section, under the damper cover, in the middle.
Part numbers:
240554502 - control board
5303918255 - defrost heater kit
Can't find the part number for the defrost thermostat
Oct 17, 2009 | Frigidaire FRS26R4A Side by Side...
My side by side frigidare is barely blowing air and its not cold at all. what could it be?
Your problem most likely is the Adaptive defrost timer . Click here if you need one CLICK HERE=> Part Number 240554502 Adaptive Defrost Board
The next most likely reasons for this is a burned out defrost heater part number CLICK HERE=> PART NUMBER 5303918255 DEFROST HEATER KIT
Or the defrost thermostat and fan motor. All in that order. Let me know if this is helpful and please rate me. Thanks Sea Breeze
Aug 01, 2009 | Frigidaire FRS23R4A Side by Side...
Fridge and freezer running too warm
You will need to unplug the refrigerator and remove the back panel inside the freezer. Check for ice or a frozen over evaporator coil. If frozen defrost and we will need to examine the defrost heater at the bottom of the evaporator. It may have a glass tube covering the heater element inside. I want you to check to see if it is burned out. The part number for the defrost heater is WR51X10042
You please let me know what you find. If the element is burned out I recommend you replace it and the defrost thermostat part number WR50X10068
You and order the parts by clicking the link below and entering the part number into the part number search feature and click FIND IT. Let me know what you find, Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Here is a photo of the defrost heater.
WR51X10055 Defrost Heater
WR55X10656 Mother Control Board
It is possible that there problems with you mother control board. Need to unplug and examine both sides for burn marks.
If you need help feel free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
Jul 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS2556 refrigerator
best way to defrost is to turn switches to off positions
May 13, 2008 | Samsung RS2556 Side by Side Refrigerator
Defroster problems
tduck, what the tech was refering to is the adaptive defrost board. This is a common failure on these models. You are going to find it in the refrigerator side. Remove the temp control end knobs from the controllers. Remove the screws holding the light shield. Now in the back on each side you will see a tab that pushes in and the cover will pull straight out. This sometimes can be difficult task, those tabs are a real pain. Now you will remove the screws holding the defrost timer cover and the defrost timer will be in the back on the right side. On this defrost board you will see L1 and test right next to eachother. Using a small screw driver short across these terminals with the harness on. This will put the refrigerator into the defrost. If it goes into defrost and jumps right back out, you know it's the defrost board. The defrost bi-metal will be normally closed and open to terminate the defrost. So if your evaporator is warm, it will not go into defrost. You should be able to get a breakdown of this at Sears.com, go to appliance parts and enter your model number. Usually the adaptive defrost board is the culprit, I don't see too many heaters or bi-metals (defrost terminators) go bad. Your part number for the board is 61003990 for series 10. See if your serial number starts with 10.....Catriver..post back.
Dec 23, 2006 | Maytag MSD2756GES Side by Side...
Heating & Cooling Logo
43 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
